FREEME ✌ LUMINTOP FWAA Andúril 2 14500 Flashlight Deals - CL2 Bundle Deal
Ordered the SST20 4000K…… Thanks man :beer: :beer:
Both of mine came in this afternoon along with the Vapcell H10s, Nichia 3k and SST20 4K. Man these are much smaller than I figured, they’re awesome.
The mailman did me a solid today…wasn’t expecting it until maybe tomorrow. Happy to see the “bunny” snuck in the back door :wink: .
Some quick observations:
The threads were pretty dry. Cleaned and lubed. Anduril 2 (yep), substantially different navigation than the straight up Anduril 1 I’m used to. Switch feels pretty solid. I got Nichia 4000k, great tint. Ain’t no lie this little puppy gets scorching hot in short order (Vapcell H10). 10-15 seconds on turbo will curl your hair. Haven’t had enough time to fiddle with the temp throttle, just calibrated base temp. I’m not getting the second flash/buzz to set the threshold. Overall I think it’s fairly impressive.
Been playing around with both of them for a while. These really are great little torches, one question though. In Anduril 2 is the sunset mode default time only 5 min? I know you can add time in 5 min increments. In the original version default was 60 min.
I received my FWAA sst20 4000k today, really happy with the light. The build quality and tail switch feel much better than my first batch FW3A. I can’t believe how small it is too! I’d definitely be in for a titanium or stainless steel FWAA if Lumintop wants to go that direction.
Sunset Timer
In the ramp mode or candle mode, it's possible to make the light turn
itself off after a while.
To activate the timer, go to the brightness you want and then use a 5H
action. Keep holding the button, and the light should blink once per
second. Each blink adds 5 minutes to the timer.
In ramp mode, it slowly dims until it's at the lowest level, then shuts
off. In candle mode, it stays at the same brightness until the final
minute, at which point it dims and dies out.
The user can change the brightness while the timer is active. If this
happens during the final few minutes, it also "bumps" the timer up to a
minimum of 3 minutes. So if it's getting really dim and you need a
little more time, you could do a 5H to add 5 minutes, or simply ramp up
to the desired brightness.
Credit: toykeeper | Source:http://toykeeper.net/torches/fsm/anduril2/anduril-manual.txt
Sent. Bundle deal is available now.
Thanks, I’ve read the manual but it still doesn’t say what time is default.
Just got them.
I must say that this little one is just asking for longer bezel like FW1A and single emitter TIR option.
Prescious metals also.
A little size comparison:
FW3T - FWAA - FW3C (18350)
SC5c II - FWAA - SC53w
DQG Slim AA - FWAA - DQG Tiny AA II
ReyLight Pineapple - FWAA - ThruNite T10T
Lumintop states a length of 70,9 mm in the manual and on their various websites, but that is not quite correct.
I have measured the following:
Length: 74,5 mm
Head diameter: 20,5 mm
Body diameter: 18,2 mm
Tail diameter: 20,4 mm (diameter of the protruding clip ring: 21,6 mm)
Weight (empty): 33,7 g
Thanks for the great photos Noir! :wink:
And it confirms what I said before
Great!!!
yep, the DQG Slim AA is indeed a bit longer. I have measured mine at 76,6 mm, 2,1 mm longer than the FWAA. The DQG Tiny AA II (which is of course a twisty) is 68 mm long, 6,5 mm shorter than the FWAA.
Interested in one
Can I have the code please? Many thanks
Interested. Please send the code. Thank you!
I can’t believe it’s that much smaller than the reylight Pineapple… dammit, maybe I will have to order one of these. But I’ll probably just wait for brass to come out, if it ever does. Because it really should - freeme
Arrived today. This is my second Lumintop, and this one is even more impressive with the Anduril 2 driver. Soooo small. I haven’t got my head around the interface yet, but I will.
Thanks for this. I am very pleased.
it sure does! I’ll keep mine in simple UI with a greatly reduced top ramp - no turbo. I can always put it back in advanced UI if I want to show off for 5 seconds.
Mine is in the US, but they can’t seem to hand it off to USPS.
I would really like to see a stainless bezel for this light, I use one on every EDC… lets face it they get dropped.
Assisted from that, I am excitedly waiting for it!
Ordered with the 219c 4000k. Thannks Freeme!
