Not really, just check your syntax before compiling and don’t flash full FET firmware on lights that can’t handle it. On another note, I tried to modify the AUX battery voltage settings, but for some reason the purple level (4.0v+) doesn’t work.
Forgive my text here, I don't know how to keep the spacing correct with code blocks. Upper section is my alteration.
#if defined(USE_AUX_RGB_LEDS) && defined(TICK_DURING_STANDBY) uint8_t voltage_to_rgb() { static const uint8_t levels[] = { // voltage, color 0, 0, // 0, R 34, 1, // 1, R+G 36, 2, // 2, G // 37, 3, // 3, G+B no Cyan 38, 4, // 4, B 40, 5, // 5, R + B // 44, 6, // 6, R+G+B // skip; looks too similar to G+B 255, 6, // 7, R+G+B }; // static const uint8_t levels[] = { //stock fancy // voltage, color // 0, 0, // 0, R // 33, 1, // 1, R+G // 35, 2, // 2, G // 37, 3, // 3, G+B // 39, 4, // 4, B // 41, 5, // 5, R + B // 44, 6, // 6, R+G+B // skip; looks too similar to G+B // 255, 6, // 7, R+G+B // }; uint8_t volts = voltage; if (volts < 29) return 0;
uint8_t i;
for (i = 0; volts >= levels[i]; i += 2) {}
uint8_t color_num = levels[(i - 2) + 1];
return pgm_read_byte(rgb_led_colors + color_num);
