Nice mod NeutralFan! And always clean :heart_eyes:
Hum, to help answering jon_sliderās question about Anduril driver, would I be wrong saying that: to use a driver with that firmware in a Convoy S2+, it would need some major mods (inner tubes, eventual pill adapting, different switch, ā¦.) to make it work, and that to use this kind of driver (FET) with those leds, it would need some āthrottlingā to maintain the max current on/under 4A?
Or a piston drive , which I assume isnāt much simpler to achieve .
Anduril isnāt limited to FETs (which indeed would burn the E21As E17As) 7135s can be used for constant current, also linear FET or buck/boost.
Mike Cās B17 clicky boost driver would be more suitable, while not Anduril I imagine his UI will be much more advanced and configurable than Convoyās, it is also much more efficient, with proper moonlight, regulation for the full battery etcā¦ a very nice upgrade for an S2 and compatible with quad E21A/17A since those can be configured as 3, 6 or 12V.
Thanks for the correction and further information thefreeman
I wasnāt considering MikeCās driver as it is not ācomercializedā as other drivers with Anduril, but it is too an option for mechanical āclickyā flashlights!
A piston driver such would also imply some modding too so I guess that it would be no different from the e-switch in terms of work!
One of my favorite lights in my collection that I will never part with got a new shorter tube to try on.
Quite awkward to hold with 18350 but I had to see. Thorfire C8S Switch, Convoy 18350 C8 tube, kiriba-ru heatsink head + his mods and spacer to turn it into ANNA-6 (not pictured), SS bezel ground down by kiriba-ru as well. It legos, not as smooth as the Thorfire tube but it works.
Wouldnāt it be great to get a constant current driver with Anduril and limit it to the current you specify?
With my E17A flashlights, Iām using a Convoy Driver for SST40 ,12groups which maxes out at either 5 or 6 amps depending on the size. I then set it to group 8 which limits the current to 50%, so either 2.5 or 3 amps.
Ideally it would be nice to go up to 4 amps, but with the 4 modes up to 50, Iām very happy with the driver and the flashlights get plenty bright. The 0.1 moonlight mode is very low and the driver accommodates a lighted tail switch without a bleeder resistor, which is also very nice.
Recently I bought some 5A/6A Convoy drivers (17mm/20mm simple 4 mode and the 12 groups). They installed single R020 instead of the older ones with R010, I donāt know if another parts might changed too, but it still managed pulling 5-6A at the tail. So you need to make sure before changing the resistor.
