yep, the DQG Slim AA is indeed a bit longer. I have measured mine at 76,6 mm, 2,1 mm longer than the FWAA. The DQG Tiny AA II (which is of course a twisty) is 68 mm long, 6,5 mm shorter than the FWAA.
I can’t believe it’s that much smaller than the reylight Pineapple… dammit, maybe I will have to order one of these. But I’ll probably just wait for brass to come out, if it ever does. Because it really should - freeme
Arrived today. This is my second Lumintop, and this one is even more impressive with the Anduril 2 driver. Soooo small. I haven’t got my head around the interface yet, but I will.
it sure does! I’ll keep mine in simple UI with a greatly reduced top ramp - no turbo. I can always put it back in advanced UI if I want to show off for 5 seconds.
Anyone know how the tints compare for the Nichia 219C 3000K and 4000K versions?
Any projection of CRI on these two and for the SST-20 4000K?
Apologies in advance if this was covered earlier in this thread.
Since this is a FET +1 driver, this should help the tint issues normally associated with the SST20, but I’m really curious about the two 90CRI Nichia’s. Can anyone with those comment on the green/pink tint of these options?
I’ve got Nichia 3k and 5k. Both floody and 5k is not bad bad for low cri but beeing called Nichia AND not High CRI botherd me so i swapped with Osram’s.
I still have a mixed feelings about 3000K, seems to me a bit yellowish/greenish... Need to compare with other light i have (but i need to find that one first)
