Hi Simon, rather sad …. would appreciate if Convoy would continue in the “high quality” space.
And I indeed would appreciate moon for AA lamps as well - even more than for 18650, because the former are more used in low-light conditions.
And of course, this would be a USP vs. many other AA lamps !
Reg. the sub-options: why is bat-check only available together with the strobe modes ??
Other than that, I prefer 1/20/100 (1.5) and 1/10/35/100 (1.2). For special cases maybe 1/10/50 (1.8). Never would use any of the other mode grps.
Btw: any plans for colored bodys for AA ?
Edit: ah, and I prefer no memory, or at least be able to disable mem !
I’ve have some S2+ with 2700k and 5700k and the tints are fantastic. The 5700k has a very slight green tint but hasn’t caused any issues with photography. If you follow the Instagram link in my signature you can see some photos taken using these lights.
Oh no, I whished for 0.1%mode on T2 but also 0.2~0.5% should be fine
Simon for your others FW Drivers can you consider to put 3 more groups?
0.1% 1% 10% 45% 100%.
0.1% 1% 10% 35% 70%
1% 5% 20% 50% 100%.
It will give more flexibility based on the type of driver used and limit the maximum power for extend runtime.
