Thank you for the info TA. Good to know, I just didn’t want to have to start thinking about potentially considering swapping driver wires out, i probably wouldn’t of anyway if I’m being honest.
When is somebody gonna hurry up and take my money for this already???
Does anybody know if people be offered one of these in the order of their post here or will it be offered generally again and then it’ll be first come first serve?
I NEED to make sure I’m one of the ones that’s in for one of these!!!
Think I have only a pair of P42A's, should get more. They have the initial dip compared to a 40T so don't look good for 0-30 sec tests, but slighter better then the 40T for the full period of drain, and of course slightly higher capacity.
Looking at the specs from HKJ's reviews, the cycle life looks way better:
P42A: Cycle life: 500 cycles at 4.2A charge and 10A discharge for 80%
40T: Cycle life: 250 cycles to 60% at 6A charge and 35A discharge
Charge rates are different, but still... Hhhmmmm. Those high charge rates we don't do, so I'm not even sure this info is relevant.
I was only teasing, lol. ;-) But WildTrail has got more in the oven already, so don’t put that extra battery too far away. :-) Last but not least, I agree the P42A on NKON was an offer too good to let pass. I just figured I didn’t buy enough for a triple battery light. :FACEPALM:
By the way, Jacky gave me some explanations concerning the battery carrier and the two LEDs in the center part that indicate the charging/discharging status. I will soon post some more information here, maybe including some first hand videos for illustration. He is now checking cut-off voltage when discharging via USB-C. I was also very pleased to hear that WT90 will work with smart chargers, i.e. type C to type C cables.
TA, I guess I will keep you busy posting another new link for the updated manual, lol. :-P Anyway, it will hopefully be the last update, so the print job can commence by the end of this week.
Is it just me or are those two comp’s impossible to decifer? P42a tested at 10amp discharge and 40t tested at a 35 amp discharge??
Anyway, I have quite a few p42a’s, identical performance to 40t, guaranteed fresh cells if buying from authorized dealers, and in 2021 at least half the price as a 40t. Mooch has some good relevant info on how they measure up (and surpass technically) the 40t, except for that first 30 seconds like you said.
Oh man, now I’m gonna have to go back and count how many requested a silver one before me. I requested mine on the 150th post so I gotta read all 149 before me and see if I made the cut.
Riiiight, there are new posts on this everyday and I can’t take it!!! I need the peace and comfort of knowing it’s been ordered already so I can go on with my life.
I just counted and there are about 21-22 silver requests before me so if there are 25 exactly like we’re told…I should be in for a silver of the first batch. HELL!!! YEAH!!!
I guess I will be incessantly looking for my invite to buy that bad boy everyday until it happens.
Correct, although they also said they will be putting in an order for more silver lights that should be ready in 30-40 days, so anyone that misses out on the first batch won’t have to wait that long to get a silver light.
They are making more clear lights, it will only take about 30-40 days so worst case you can simply wait for the second batch of silver if you want as well.
More light mods - adding bypasses to the carrier springs
The carrier is easy to disassemble with the right tools. Believe I got this tool kit from BG. The tips seem more precise than a cheaper set I had. 22 AWG wires shown
Here's the USB charging circuit:
22 AWG bypasses installed. I usually do bypasses internal to the spring, but with the compression these springs can get and how little interior space they have, went with outside mounts that won't interfere with compression:
Results were marginal though. Probably could have used 20 AWG wire, but didn't expect much after the more significant bump with the driver spring bypass.
I did run a test with a set of 50G cells, but stopped it after 3 minutes because of heat. Outside temp reached 57C. Took a few minutes to cool down to 41-43C, where it was comfortable to hold. I don't think I gave it enough cool down time from prior turbo tests on 40T's and 30T's. After this carrier spring mod, first tested on 40T's (results above), then 30T's and got slighter lower results than the 40T's, then the 50G 3 minute test. So in between, probably should give it 15-30 mins of cool down time, but didn't.
Comparing these results to my Noctigon K1 with spring bypasses, the K1 on a 30T measured 22.3 amps, 5410 lumens at start (about the same the WT90 does stock).
I'd have to guess the WT90 is doing about 30 amps after these spring bypasses. I don't have an accurate way of measuring lumens on a GT90, but I'm guessing this WT90 is doing better than even my spring bypassed GT90's.
