I measured parasitic drain through the carrier with this setup:
The red wire is 14 AWG, and all I had to do was put the DMM probes on the carrier edge and the brass driver retaining ring.
I tried measuring amps on turbo with this setup, using a 10 AWG black wire, but only recorded 20.5 amps, pretty sure it's much less than what it's getting assembled.
Parasitic drain with the switch LED OFF: 26 µA (through the carrier or not, same reading)
Parasitic drain with the switch LED ON: 9 mA
There's gotta be resistor problems with those green and yellow LED's. Didn't take a close look at it yet. The yellow is very bright, and that takes a lot of power to do. Green, as an example, takes less power to be bright. They will be changing/fixing the switch LED's in production, as TA mentioned.
Thanks a lot. So, it seems three out of four quarter segments will be used to indicate something. A blue LED for discharge mode, another red LED for charge mode and a third LED that flashes red while charging or discharging. The only question remaining is, if this flashing LED can turn to constant green or blue when charging is completed - or will it just turn off? Jacky told me there will only be blue and red LEDs in the final product (I guess he meant on the carrier PCB only but I am not sure).
USB-C type C to C support should better be removed from the manual after your testing. Usually, some resistors in the USB’s circuitry should be able to override device identification by any smart PD charger. The battery carrier should then be identified to not more than 5V 2A, similar to Sofirn‘s LT1 in its latest revision (driver rev. 5.0). Maybe TA can advise WildTrail to do the proper steps?
Alright, so I understood following:
There are LEDs both on the carrier and underneath the switch button. The carrier will apparently not use all LEDs that are soldered onto the PCB. I only saw red and blue LED colors which is now in line with that what I was told by Jacky. The switch LEDs seem to be using green and yellow LEDs, right? So, these show a high parasitic drain and here there will be some fixing by WildTrail.
WildTrail confirmed they will use green LEDs for the switch button and red and blue LEDs for the battery carrier in the final product.
Since Tom E observed that USB-C type C-C cables did not work with a PD charger I have updated that part in the manual. Tom, do you have any chance to test discharging with a USB-C to Apple Lightning cable? From my experience (Wurkkos HD20 for instance) some USB-C circuitries may not work with Apple Lightning cables to recharge iPhones or iPads. I fear we may encounter the same situation here. Not a big deal but maybe worth having a look at it anyway?
LVP @ 2.9V added to the manual.
I revised the section about the battery carrier as shown below.
What I saw was the blinking red LED turns green - seemed to be in the same place, so the 1/4 stayed solid RED, and the blinking RED turned GREEN.
I don't know about removing the USB C to C from the manual - don't know if it's only a prototype problem.
Missed answering this - I only noticed a green LED was ON when I exposed the switch PCB. Fully assembled, can't see the green and in room light, all I see is yellow on one side, but in the dark, the full ring is lit up yellow. I would have to fix up the resistors myself to see what it looks like balanced. I prefer the look of yellow, but from experience, it will be a higher drain.
Think I got a pic of the switch (not uploaded), if not, I'll take one. Been working on the switch this morn, actually. They used 2 330 ohm resistors, one to each LED, on the ground side of the LED's. So the green LED's are higher voltage (3.0-3.2V) and the yellows are 2.0-2.2V -- that's why the yellow took most of the current and was super bright while the green was barely lit. Ref: https://www.circuitbread.com/ee-faq/the-forward-voltages-of-different-leds
I set it up with 2 yellows and 2 4.7K resistors which resulted in a parasitic drain of ~0.8 mA, still relatively high but way better than 9 mA. It won't be as bright so need to see how it works assembled. I'm still though working on the switch so it can be tightened down.
For two greens, may try 8-10K resistors (possibly higher) - green is brighter and it will further lower the parasitic drain. NarsilM has only one brightness level while Anduril has two levels. The good thing of using the same color is the outer switch ring will be lit up evenly.
After the mods, little messy but did them in place. Replaced the resistors to 4.7K's and the left LED from green to yellow:
In bright room light:
In low light room condition:
It looks great now in the dark
Also fixed the switch - it can now be tightened down (cut the rubber switch overlay's center stub down).
I do like switch LED's in RED, YELLOW or PINK, but for the RED's and YELLOW's, you pay the price in parasitic drain because you have to use lower value resistors to get them bright enough.
yeah, that is why I generally recommend green or blue LED’s as they need less power for brighter light. Looks good!
So both LED’s are run in parallel from the driver or dot hey have separate wires? The driver also has a spot for LED resistors, technically the resistors could be added there if they are run with separate wires (seem to remember 4 wires coming from switch?)
For orange, a few times I used 1800K Luminus Cube leds, they are very orange but phosforconverted so a bit more efficient than genuine orange leds. The voltage of course is the same as blue leds.
It’s almost 2 weeks since your first post about this awesome light, the expectations were that it would become available in about 2 weeks.
Any updates about the expected dates?
They are sorting out the switch LED’s issues now, that delayed things a bit but better to deal with it now then have to try to fix it later. So they are ordering new switches for all the lights and will be taking all the lights apart to replace the switches this week.
Hopefully they can sort out these issues this week but have not got a hard date yet.
I did get a confirmation last night that the carrier LED’s in production will be blue/red and that the switch LED’s will be green. They are wanting to use a 4.7k resistor on the green LED’s but I told them to do a current test before they settle on that to make sure it is good.
So progress is being made, just last minute issues that are being sorted. They want to ship them as fast as possible after taking your money so trying to have them ready to go.
While I hope they can sort the issues this week, I would figure on there being another bump in the road and the order page not going live until the week after but I would love to be wrong.
