I haven’t used Anduril 2 to know whether I’d like it or not. Now I’d be completely happy for Anduril 2 to be tweaked so there’s a Turbo in the Simple UI. Also chuck in the 2C to Turbo as per the standard for so many existing brands and models.
I already had 2C Turbo enabled in my build. But I tend to think you’re right about enabling max output in the Simple UI. To me, Simple UI should be easier to operate, not necessarily be limited in output (like was a consideration for the old Muggle Mode).
Ah, excellent. Then I’m all for V2, those were my only issues thanks for the response. If I stock Anduril 2 I’d increase the ceiling to level 150 if it doesn’t get added
I can only agree with you in every way. :-) IIRC, that’s exactly what Sofirn was looking for if they decided to sell any flashlights with Andúril 2. If SIMPLE UI had a lower output by default, they would fear major complaints from customers.
What would the output be? probably need to keep in mind that Sofirn’s 14500 cells are a bit restricting, maybe keep to something they can manage, perhaps the same setup with this new driver
