Hi people
I need to make a lanyard for my FW21 pro (I just love this light) But do not have a clue how to do it so if anybody knows how or has any links that would be great.
I did a search but could not find anything that shows you how to make one when having no hole to go through. I do not use the clip so it needs to go around the body and I would like to use one bead.
Hum, I would suggest picking some paracord (or a different type of thread) and making a lanyard around the flashlight tube.
The “turks knot can be a start, but the simpler ”cobra knot” can also work!
Classy…I like it!
Just curious, as the tag end is out of frame, did you create a loop to run your hand through, or is it more of a “fob” with no anchor loop?
Nice work.
No loop just two ends. I measured the skull so it fits perfect between my fingers for a good fit.
So I ended up starting with the clove hitch knot for a nice tight secure hold then snake knots finished with the diamond knot.
Have your guy got any to show?
I just ordered a new bead so will try some new (harder) lanyards.
