Anyone have both? Can you gives comparison of them?
I watch tonnes of YouTube videos before buying. I bought the BLF 5000k. But afterwards I’m not so sure if I made the right choice.
I like a good beam high CRI but I also like a good throw. And I want them to have a good runtime perform well not only on a short period of turbo bit also on lower level.
Something that perform admirably in practical use.
I just did me some google to decide between these two for myself and found several YouTube’s comparing them together and with other lights. Here on the forum I think that asking a more detailed question about what you actually want to see or know will give more response.
For what it’s worth, I bought the SP36Pro in 5000K for myself.
Blf version is Hi CRI which is advantage in most case. The pro version is more powerful but it will substain that lumens for few seconds so it is not big deal. I want to buy PRO version because really like it SP36 in any variant. I have also blf version as a kit but it’s not assembled.
From my experience with XPLi version of my SP36 I think that is around 1500-2000lumens max for longer times depending on surrounding temperature of the air.
I wanted to know what the OP does prior to buying my SP36pro. I shot blind and went for the most lumens and price with the ‘more is better theory’. But as you learn about emitter types & there characteristics, drivers, reflectors etc you start to get a better picture as to how any light will perform & whether you’ll like it. I still don’t know if I bought the best choice for me but I do like the SP36pro both for it’s performance & size. 3 cells is much nicer in my hand than 4 but still has lots of capacity & powa. FWIW,I like ALL the blf lights I own, behind their creation are knowledgeable folk who have passion & pride who put function, quality and performance before profit. Often the end result trumps lights that are 3x the price.
Deciding between these two versions of the SP36 is like the classic quality over quantity choice, do you want the nicer and warmer light and a bit better beam go BLF or do you want the brightest with the longest throw go Pro.
All these lights, not just these two have the turbo fall back in some way, the SP36 lights have active temperature management so turbo stays on maximum longer on cold days as on warm days and you’ll need to calibrate the temperature for maximum turbo effect. In my experience the turbo-setting stays very bright even when falling back some but it has been pretty cold so far this year.
I’m happy with my choice, I went for max fun and the fun I got is awesome, bought it as a play-light and I like playing with it.
I watch lot’s od YouTube review and read people’s comment on them on Reddit and Facebook. While many say that the blf gives better tint some says the pro version is not that bad. And the beam pattern for the pro is more balanced with throw and spills. Except for the ring in the beam profile.
I don’t know how much better the high CRI is compared to the sst40. And if the pro is really much brighter and throwier than the blf.in mode other than turbo.
I would like better runtimes too at comparable brightness in other levels too.
those are questions everybody needs to answer for themselves. Me personally I like hi-CRI especially at shorter range and inside so find it more important in smaller lights. The lights I have for outside use, I think CRI and perfect beam a bit less important thou I rather have no CW so I got me the 5000K SST40’s, mine and the Pro’s I saw on YouTube are all nice and white, no trace of green at all.
