What did you mod today?
What better and fast method to make the surface of the shelf lapping and remove those residual steps?
I thought first file the edges of the pill (2mm height of material) and then get to the shelf with fine sandpaper
I never found an easy and good way to lap a surface inside a cavity, just tedious imperfect ways. But on some occasions when that was no problem I have indeed removed the entire edge of a pill, then it is easy to make a perfect surface.
Looks like that pill screws in from the front of the torch. So it relies on the ‘lip’ to stop the pill screwing in too far.
So long as you don’t completely remove that lip or the tweezer holes, it’ll be easiest to cut back the edges like you mentioned.
like this?
View post on imgur.com
Yes,pill it’s from old C8 with glued 16mm Led…that I would mod with 3A driver + SST20 or 5A XP-G2.
At least the shelf is not concave,but have machine marks and lacks screws that hold mcpcb.
I’m afraid that the pressure of the plastic reflector isn’t enought for heat transfert,
I have also a spare Alu reflector,but it will require a 20mm mcpcb to avoid short circuit and enlarge holes cables
in this flashlight i have a SST40 driver 5000 Ma and a XHP50.2 3v and no reflactor because it’s a zoomie, no heat problem
Zoomie’s usually have screwed down mcpcb and/or a threaded shroud over the pill that presses on the centering ring/mcpcb. These things serve the same purpose as bezel pressing down on reflector/mcpcb.
Added some glow … sorry ‘turbo glow’ to the fwaa tonight. (apparently you can’t just say glow anymore, it has to be turbo :wink: )
yes i know, for me works without any
Cool! :sunglasses:
May I ask where did you get it or how did you do it?
It’s not that hard. Just a bit of glow tape stuck to the inner circumference of the head :person_with_crown:
AHHH! :smiley: The same kind I normally do :stuck_out_tongue:
I just thought it was a “triple” glow gasket and was wondering if they were for sale out there!
I need to order some more GITD tape so I can “turbo glow” it :wink:
I added a red channel for someone to their FW3T. It’s running Anduril 2 with the stepped ramp replaced with a smooth red ramp.
I think someone has done this before to an FW3A. I recall seeing something similar a long time ago but can’t find the post.
:+1:
No details? What red LED? Is the red on 1x7135 like similar builds? How difficult was editing firmware to make two smooth ramps? No MCPCB pics? :slight_smile:
Fair, I forgot to take photos for a lot of the process.
It’s a sst-20-dr 660nm because it’s what I could get with 1 day shipping from digikey. The footprint of the sst-20-dr seems to be only available in the B120 version which isn’t our usual 3535 footprint but has smaller pads. I only noticed after the LED wasn’t bouncing during the reflow like the other sst-20s. It’s not an issue with just the 350mA from the 1X7135 that’s powering it.
I cut the traces from the bank of 7135s and was originally feeding the red led 7X7135s but the dimmest mode was too bright so I removed 6 of them.
There was also a leaky 7135 or two on the board since the red led was dimly illuminated even when the light was off but the battery was connected. Removing 6 of the 7135s helped stop the leaking and helped make the lowest red mode dimmer than the white and the red led is still really bright with just a single 7135.
I did this mod for someone who is a pilot instructor and they wanted a red light to stop them from being blinded when flying across open water in the darkness so I made all the changes to anduril with not blinding them in mind. The light switches between the red and white modes with a triple click, and always starts on low when the modes are switched. I also added a shortcut to the red mode while the user is in the white mode.
I’m not familiar with C or anduril 2 so it was hours of trial and error, changing one value then flashing it and seeing if it was the right parameter until everything was perfect.
:+1:
nice work!
The guy I modified it for really liked it which was a good feeling after the hours of work I put into perfecting it. :smiley:
Excellent FW3P :beer:
make more, you will soon be rich and famous :person_with_crown:
Any beam shots of the dual emitter? Curious how/if it changed the beam.
