RD6018 RD6018W 60V 18A power supply is published
RD6018 customer feedback
great seller recommend, packed great
https://www.aliexpress.com/item/1005001488070904.html
hello, when you get part of your order, do not worry, you can check your order to see if there are multiple packages to send your order, or you can contact us to let us help you, no need to make dispute immediately
RD6018W feedback
The product is really nice, thank you very much about the seller, the product is wonderfully packaged but it was removed and checked by the customs on the way to Turkey
for RD series, there is a option called ”Boot Pow”,which means when you power on the device,the output will be turned on automatically,but it only applies on the normal red terminal,the battery charging terminal doesn't have this function for saftey reason
https://www.aliexpress.com/item/1005002185722889.html
it should soon , it will be 618, there is a sale promotion
RD6018W customer review
received an order! packed perfectly, arrived pretty quickly. everything works great!
RD6018W feedback
IML delivery in 3 days (during the May holidays), packed perfectly. The packaging of the module itself pleased me. I will check for heating in stress mode, pulsations, and the accuracy of the readout meters. look for Crazy_Geeks on YouTube
RD6018W feedback
Arrive faster than expected, well packaged and operates as expected. Took serveral days before it shipped and tracking didn't work but it arrived in less than 2 weeks from order so very happy.
hello, I need to say it once again, when using DPS or DPH series power supply to charge battery, please follow this: 1. check the if the connection is right, 2. set the suitable voltage and current, 3. turn on the output. the connection is very important
but for RD series power supply, as long as you use the battery charging terminal, it has no problem, even though you connect the battery in the wrong way, it will use icon to show you that the battery is not connected and will not output
DPS5020:https://www.aliexpress.com/item/32821185351.html
our another logo is ruideng
thank you
RD6018 feedback
Good seller but delivery very long time
(usually the shipping time is about 20-30 days, but for some country, because there is no direct flight, it will go other countries first and stuck there if there is no enought flight)
I bought the RD6018W and I really like it.
But tell me, if it’s limited to 18A, should I buy a power supply like 36v 16.6A ?
What happens if I install a 24v 25A, PSU to power it? Will that damage it?
This is from their AliExpress Store……
I’m reading this to mean that they do not sell a power supply capable of allowing the 110v version make full power, only at 220v can you get the full 18A.
yes, for 110v, It can’t ouput 60V/18A
With your power supply….or with ANY power supply?
If that is the case, what is the maximum output for the RD6018 at 110v ?
you should know check the all things , they said the 1000W psu on our website …
Oh, ok.
Yeah I went back and checked everything. Didn’t find the answer. You said it could not do 18A at 110v, so I asked what was the max output at 110v.
We mostly use 110v - 120v in the USA. Not 220v.
I’m sure if I knew Jack about electronics I could figure it out. Electronics dumb dumb here.
NP. I can ask someone over at the electronics forum if you don’t have that answer.
Thanks
there is a button to contact the seller, if you have any questions, you can send us message, and we will reply soon.
some frequently asked questions recently:
www.youtube.com/embed/G7bcv9By4Og
RD6018W feedback
Fast shipping. Two weeks in Belarus. Quality packaging. High quality product. The seller answers all questions. Recommend. I will order more.
