Sounds like a good idea. My only concern is the battery. Is there only one source and how has it been testing? I wouldn't want to a battery that isn't going to be around for long. What is it being used in?
Depending on the price (and whether they will be able to ship to my country), I’ll try to get 2pcs of each body tube type (2x FT03, 2x FT02S, 2x EA) and 6pcs QB26800.
(I’ll only order the 26800 tubes, IF the 26800 battery can be included in shipping to my country… otherwise, I won’t be able to use the 26800 tube as QueenBattery doesn’t ship to my country normally).
What are the 26800 battery specs? It says 6800mAh what is the constant discharge current? I have 6400mAh 26650’s so just weighing up whether it’s worth it. Also is there only one source for this battery?
MF01 Mini, EA and FT02S Tubes and end caps are fully compatible with each other. I would like to order 8 of these Tubes. 1 silver the rest black if possible.
That 6800 mah number was confirmed by Mooch at a 10 amp draw. Entry #14 by Freeme is a good set of test to look into for those wanting more information.
Really sad to hear that… there is a rapidly-growing flashlight enthusiast user base here in our country. Hope they’ll be able to find some way. I’ve really been itching to try the 26800 battery form factor every since they appeared on the Nightwatch NSX4 (which I had not tried ordering from Neal, and Neal doesn’t seem to have stock of it nowadays).
As I haven’t personally tested the 26800 battery form factor yet, I’m currently unable to convince fellow local flashlight enthusiasts about this battery type since I could not have it shipped here…
