Don't forget to make a 2x 18650 version at the same time .Seems like if it's a good design then either downsizing it and or upsizing it makes good sense .
I think a slide snap in mount for a bike light may give it some extra appeal as well as open up another possible market .
2xAA side by side done right has always been a bit elusive. yeah it's easy to do it if it's titanium and the light costs an arm and a leg .
The old school plastic lights ought to prove it can be done right .
Thanks everyone, looks like I am going to have to make the pills my self. I emailed mtnelectronics and am waiting to hear back about some of there smaller drivers. I started out wanting to use somewhat standard parts but am no going to make nearly every component in house so that i do not have to settle. the design is changing by the second but as soon as i have it a little closer i will be sure to share.
Thanks for the input everyone, Im moving along with my design and have decided to change the button and that is going to change most of my components. I want to go to an electronic button, the nature of my design just isn’t lending its self to a clicky/ latching button. Now i need a driver capable of running on an electronic/ momentary button with the lowest parasitic draw possible. I see mtnelectronics has a qlite driver that can run this type of switch, any other recommendations? looking to use a cree xml2 emitter. Also any sources of good electronic buttons? They are extremely hard to find.
It most certainly is. Im figuring things out the best I can though, sourcing components is seeming to be the hardest part as none of the parts are made in the us, they are never properly represented on line and their availability is spotty.
What im looking for in a button is really just the outside metal cap/retainer that screws in on side button lights. I can set up my own tactile switch underneath i just need a screw in metal cover/button.
The only thing that springs to mind is the convoy metal button which is not US made, of course.
Unlike rubber boots, metal buttons are usually a proprietary item on hosts. So there is very little available.
It kinda sounds to me like you are trying to piece together a ‘new flashlight design’ from existing available parts. For a tubular host that’s almost possible but for a side by side cell light that sounds like an impossibility. Or do i have that wrong… are you having a new host produced at a local machine shop?
I’m looking into those convoy buttons, the lead time in then isn’t great and it would be nice to have something in my hand quickly to know if it won’t work. I’m designing a side by side light from the ground up to hopefully produce and really at this point the only thing I’m not machining my self is the button but I’m thinking I will have to make that as well. Something like a piston in a sleeve with o rings or a similar design to the s2 metal buttons with a silicone boot only more flush and have it interface with a tactile micro switch. I’m trying to keep it as compact as possible.
DQG Tiny did some pretty small side switch assemblies. Some had a rubber boot, some had a metal button but all had a press fit retainer. I’m guessing that will save you a little bit of machine time if you press fit rather than thread.
Thanks again for all the suggestions, its taken me a few months but I finally think I have nailed my design and what to see what everyone thinks.
Hopefully the images come through, my first time trying to post them.
The design is a 2 piece light that is brought together by the thumbwheel in the center. It takes 2 14500 cells run in parallel and will run on only one in a pinch. Right now i am building them with the Qlite momentary switch driver from mtnelectronics but am open to suggestions if someone knows of a driver under 18mm diameter that can run both aa/ 14500 but i haven’t been able to find one. I have designed the head to accept 20mm carclo optics and i will be offering both in single xml2 and triple xp-e2 configurations. The “guts” of the light are my custom made pill that holds the Led, driver with momentary switch attached that can be changed by unscrewing the front bezel allowing you to easily go between different led configurations by putting in a new pill/lens.
I am machining everything my self including the button that is located on the bottom of the light toward the front. The location of the button makes the light very versatile, lending its self to many different hand positions. The slot running between the batteries is a mounting point for accessories including the pocket clip, which can be loosened and slid higher or lower, Mlok and keymod weapons mounting adapters which will be flush to the rail, and a magnet to come later.
The weight is around 5oz without batteries, 4.15 inches long, 1.65 inches tall, .8 inches wide at the body and .96 inches at the swell on the head.
I hope to have a completed final version completed this week and i will share some photos as soon as I can
