He does and he’s been using D2 for 40+ years to good effect in the bushcraft realm.
D2 can rust, so taking along a silicone impregnated cloth, might be prudent, but a simple Arkansas stone is all you’ll need.
To me, bushcraft duties are akin to ‘campfire’ duties, so a 3”–4” blade should be sufficient.
If one needs to baton a bunch of kindling from limbs, for a fire, a bigger knife will be needed. Same with a knife needed for survival, where building a shelter, or hacking through vegetation is necessary.
D2 is fine for bushcraft duties, especially German D2, since the Germans make good stuff and know their steels. All bets are off with the Chinesium crap.
For the money, a few years back, nothing could beat the Sanrenmu Land series of pocket knives. Decent steel, ball bearing pivots, just very high quality for the money. I bought a bunch of them. They are nearly indestructable.
My first thought too- D2 is too hard for hard use. Like my fixed blade ka-Bar Becker necker, made in 1095. Not the best steel obviously, but it has some give to it. Tough edged steel like D2 just has not lateral (?) strength to be bending and prying with. You want something that’s bend not snap.
D2 is fine steel, about 12% Cr so often called “almost stainless” steel, at that much Cr it’s expected to be less strong than real Carbon-steels but it’s still pretty good compared with most stainless-steels. In fact I’m thinking of buying a D2 outdoor-knife, have my eye on the Real Steel Bushcraft III convex.
I have one Chinese D2 budget knife, a HX Outdoors ZD-031. The steel on that one is excellent but these knives were not the cheapest back then, I have no way to confirm real D2 and it does seems a bit to much stainless but it is simply very good steel. I just wanted to try one of those China-fantastic’s so bought this one to play with: too thick and heavy for my liking so I rarely use it, it is shaving-sharp and flips and falls shut super smooth thou.
Lower hardness can be helpful if more toughness is needed. Going softer on D2 might gain a little toughness but also trades away a lot of the edge retention that makes it an attractive steel in the first place. Based on just a few tests I’ve seen from other QSP knives, they run their D2 around 58-59 HRC. Another potential issue could be the purity or consistency of the Chinese D2. We know from LTK’s XRF testing that the composition can vary on Chinese D2.
The German K110 should be better in that respect. The bad reputation on Chinese D2 has given Petrified Fish, Bestech, and a few other brands that usually use it a reason to start importing K110. Either way, the toughness is still only around 5ft/lb at 60HRC. I’d rather avoid these issues in the first place and use a steel like 14C28N. Aside from being much more stainless, 14C28N has roughly six times the toughness at similar hardness!
BTW, if you don’t mind messing up your knives then you can do a mustard test for D2. The steels used by unscrupulous companies to substitute for D2 are usually 3Cr13, 5Cr15, or 8Cr13Mov. All of those steels are notably more stainless. After thoroughly cleaning with isopropyl alcohol, you can put a blob of yellow mustard on the blade for an hour and see what happens. I recently tested this on satin finishes at around 68 degrees Fahrenheit . At just over an hour, Walmart’s Organic Yellow Mustard left a permanent gray mark in the shape of the blob on D2 but wiped away pretty cleanly from 8Cr13Mov.
I use the bread you can buy for a long sub sandwich . You can order 3 to 6 foot lengths from most bakeries.
For a slim knife like a bayonet, regular French bread works fine . A loaf of Italian is perfect for Bowie knives.
And you always have a snack handy if you EDC in bread
Bought quite a few over the last few years, without a hitch; however I’ve bought nothing since brexit and would be worried about BF, since they’re confiscating (perfectly legal) CO2 air pistol imports, claiming they’re imitation firearms (they’re not imitation firearms, by law they’re real firearms, you just don’t need an FAC).
Bought about 10 knifes shipped into 4 and 6 knifes packages. All of them are small knifes about 12cm length and blade less than 5cm. Only one knife is 16.5cm and blade length 6.5cm.
The smallest knife is 9cm and blade 3.6cm but it locks. The cost taking into account exchange rate and shipping, will cost me £5.09 per knife.
… and they biffed it. I just got an email saying they accidentally oversold a bunch of their clearance stuff. They are sorry and are giving out some one-shot coupon codes for 15% off.
