FREEME ✌ LUMINTOP FWAA Andúril 2 14500 Flashlight Deals - CL2 Bundle Deal
Something I observed on my FWAA:
  • Thermal regulation is acting WAY too late, regardless how low the threshold is set. I set e.g. 45°C for stepdown but on turbo mode it’s getting beyond 70°C before actually stepping down. Thermal sensor was calibrated properly, of course.
  • If the flashlight gets warm (> 40°C surface temperature) there’s no way of getting back from Turbo. 2 clicks do nothing, I can only turn off. As long as the flashlight is still handwarm or cold, there’s no problem cycling between Turbo and Ceiling.
Interested
Anyone got any idea when the XPG3s will be back in stock?
Did anyone else get a “pinky” Nichia 4000K version already?
Or not so much?
I also really need to know that !!!
why would anyone want xp g3 emitter? arent those crappy… seems not a good choice imo.
Green 6500K?
I’d swap in 5700K 90cri lh351d :wink: OR even luxeon HL2X in 5700 90cri. I have ten Im not using. Theyre perfect for a 14500 triple
Is there ANY way of getting to true turbo while in Simple UI?
I dont think u can ? maybe if u reflash the driver perhaps? but the light goes insane hot on that mode if not careful u can burn yourself… i will use simple mode for now…
I got a slightly pink 219c 4000k.
It looks better than the SST-20 4000k I also got, especially at lower outputs.
I’ll be keeping the 219c as is!
FB
I ordered a Nichia one since I have a ton of SST-20 lights… I have a Lumintop IYP365 with a really good tinted 4000k Nichia so I was hoping they’d use the same bin. Mine hasn’t shipped yet, it’s been “unfulfilled” for a week.
My SST20 4000k took 16days from order to doorstep. Beautiful tint……. love it. Ordered 5 Vapcell H10, was only sent 2 but was credited $15 for the three that I didnt get. Not sure what happened there but Im still happy. Thanks freeme!
I think you just set the top of the simple ramp to 150. I think it even comes that way out of the box.
Out-of-the-box, the top of ramp in Simple UI mode is much, MUCH less than turbo in complex UI mode.
I find it hilarious that one thread on BLF talks about all the problems with this light while another one is taking orders for it. All at the same time.
Few of first batch buyers did receive a faulty light out from the box (FACT), but how many of those who raise concern about FWAA issue actually own a FWAA?
Ok. I was just going by the manual, as I’ve already reconfigured everything on mine. It says the default config for the simple ui is a floor of 20 and a ceiling of 150.
Does anyone know where the Anduril config file for this light is at? I’d like to see where the 1x7135 is set on the 1-150 scale.
We heard FWAA will be made in copper, brass, and Ti.
A Cu/Ti model with the Ti stonewash finishes that the GTnano has would make me bite. This thing needs a Cu head though for the Ti versions. It barely get’s by with Al.
NOW for the bigger question… What about a SINGLE emitter version? Pretty please?
