The little coin cells finally died but instead of replacing them I replace the whole thing with a QX5252 circuit that is powered by a single AAA battery. The cool white emitter has also been replaced with 4000k rngwn 5mm
My E3S came in - the last purple they had in-stock on their aliexpress store. The UI is steaming hot garbage, so: is this board/BOM available? I think assembly will be easier on the shorty at least.
My boards are available on Oshpark, so are Loneoceans’s if you’re interested in the aux. Almost all parts are fairly standard FET+1 components with the exception of the attiny1616 instead of the attiny85. Unfortunate with the chip shortage those are pretty much impossible to get right now.
Awesome thanks - I forgot to check again, and the last time I looked I didn’t see it (may have been my oversight).
I’ve actually got an assembled loneoceans aux board from my Lume1 which I’ve decided is unusable (due to lack of RPP). I’ll order it eventually, between that and the 1616.
"GT90 Mini" - OK, so i know others have done this already, but what a FUN setup. Gt mini pro (OP reflector) with the sbt90.2 in it. I selected the mini pro because of its higher amp driver, otherwise i really wanted to use a smooth reflector version like the standard GT mini. But the OP reflector actually works pretty well, and i am definitely getting close to the KCD if not more than my ft03 xhp50.2.. Going to take some measurements after i tidy up the install of the sbt90.2 by reaming the reflector and centering it a bit better.
I have the thermal regulation turned off (thanks to the awesome gt driver) and honestly it takes about a minute which is way better than I thought it would be. I feel like I can push it more, I may try bypassing the springs this weekend see if that gets me anywhere. I am running a molicel P26a battery. It is fun though!
So today I built my old Thorfire VG-10S light into a gift for my father, who will be visiting soon (finally everyone is vaccinated and he gets to meet his 9mo granddaughter).
LD-A4 driver at 6A
Luxeon V with on-MCPCB NTC
Large BlueSwordM springs at each end
I also almost completed my Sofirn D25S build - only to realize I only had one 16mm 3535 MCPCB. D’oh!
I also put a cslnm1 in my Convoy M21c with 6amp 12 mode driver. The thing THROWS! It's the same one I heated the SS bezel on to a golden color. I'll have to post a beam shot, it's a 55mm head size with a cslnm1 osram, really awesome setup. It might rival my CULPM1 K1 in throw really, or get pretty close.
my next mod- CULPM1 and 8aml driver came in from Simon, going to put them in a m21a I have that currently has an sst40 (the sst40 is just not impressive in the m21a when I compare it to my original with 6 amp with cslpm1). I'm thinking this 8 amp driver with CULPM1 in the m21a will be quite fun!
