I've tried to determine some Anduril firmware versions (or a guess) of a few Anduril flashlights that I've checked out:
Meote FM1 copper = has version check: 2019-09-28
FT03-Mini = has version-check: 2019-09-28
Sofirn SP36 BLF Anduril, Sofirn IF25A, Astrolux EC01, Astrolux EC03
= I think it has been determined by TK that they run the same old version of Anduril:
all of them do not have the 2-level brightness in lockout mode, nor manual memory mode. So firmware has to be earlier than 2019-05-22 (this firmware date added the 2-level lockout). The button blinking is a "breathing" pattern, which is added in Anduirl firmware date 2018-12-14. So the firmware used by these flashlights would be somewhere between 2018-12-14 and 2019-05-22.
Astrolux HL01 = has 'factory reset' function, but no 'version-check' function [between 2019-06-27 & 2019-09-24]
Astrolux FT03S = has 'factory reset' function, but no 'version-check' function [between 2019-06-27 & 2019-09-24]
('factory reset' added in firmware version 2019-06-27, 'version-check' added in 2019-09-24)
which would mean these 2 flashlights have Anduril firmware version dated between 2019-06-27 and 2019-09-24
Haikelite HK04
- Anduril version 2019-06-02 (has manual memory via 5H); but no factory-reset function
(firmware 2019-06-02 added 'manual memory' function; 'factory reset' added in 2019-06-27)
I tried to check some functions of Anduril (in the Anduril repository change log) to help determine which functions added in which date (for Anduril versions that didn't have the 'version-check' function yet)
2018-12-14: fancy aux-LED (button switch LED) blinking mode (like heartbeat breathing effect) on BLF Q8/SP36
2019-05-22: 2-level lockout brightness (4-clicks); momentary strobe mode possible (go to strobe modes before going to momentary mode)
2019-06-02: manual memory option (5H) ; button-release time-out is a bit faster
2019-06-27: factory reset function (hold button while tightening the tailcap)
2019-09-24: version-check function (15C) ; safety ramp-down if button held too long
Since I don't see any "Anduril 2" category on the initial post of this thread (list of lights classified by UI), I'm wondering: are there any lights currently sold with Anduril 2 already installed?
The light seems to look like an EDC18, except it uses quad XPL-Hi (instead of the EDC18’s triple LED).
Product description does not mention “Anduril”, but the listed modes (including ‘storm’, ‘candle’, ‘beacon’, ‘sunset’, even ‘muggle’ mode) and usage operation (how to factory reset), matches that of Anduril.
Must be Jetbeam’s first Anduril-based flashlight, if it really does use Anduril.
