True. The part about waste is not going to change though. If you draw a grid of circles, 1 circle will touch its 4 nearest neighbors on 4 infinitely small points. In between all the connections will be a small cross of wasted scrap material that can’t be used.
Bose301s (mr. know it all) - try watching the link I posted and learn something. I can post three more from different makers of LEDs that show virtually the same thing. You want them? Saws? Really? Oh, hell no. You must be going to Fred Flintstone's LED Cave to watch something like that. I imagine folks are lining up at your door to buy your homemade LEDs. What does it cost you to do gallium arsenide deposits on the metal substrate? What class of clean room do you use? Do you even know that clean rooms come in different flavors (classes)? You must be very rich to have all this wonderful equiptment? I'm pretty sure you might know something I don't but I'm equally sure I have no interest in learning how to pick my nose in a new way. Only 16 posts and already I have some clown (Nyah nyah, I know more than you do) climbing up my butt and resorting to personal insults. Is that the best you can do, smart guy? Lame at best. I posted the link for all to see but I guess nobody bothered to look at it. Maybe you should have.
As I said before, yes, there is more waste. You were right about that. Sort of a no brainer observation though. Congrats!
Again I don’t need to watch your link as I work in the industry, and again, I have seen with my own 2 eyes the dicing saws.
Lol, so much bad info in that post it's not even funny. Gallium Arsenide is for Red LEDs, blue LEDs are InGaN or GaN. LEDs are generally grown on Sapphire or Silicon Carbide wafers, not a metal.
I work in a class 1000 clean room, but we also have class 10,000 and 100 based on the needs of that particular manufacturing step. Obviously you have a slight knowledge of this stuff, but not very much, and definitely not as much as you think you do.
What a suprise! You are obviously a smart guy - maybe. For all I know, you are the janitor there. To smart to watch the video and see how others do it, eh? Or just to smug? I'm aware that different materials are used for different types of product. I saw no reason to write a book to include all the possibilities. Resorting to personal attacks because you got your feelings hurt is not smart at all. I have no idea who you work for and I don't want to know, but I can say with confidence that if you guys are currently using saws to cut out individual LEDs - you either wont be for long or you will be out of business soon. NONE of the big 4 use anything but lasers for their new products. Check it out for yourself. Do some homework and broaden your horizions. The LED industry does not start and end at your place of employment.
I don't really care about waste or cutting them in the most efficient method, they could even make individual bases for them to sit on for all I care instead of cutting them out, that would waste nothing. I would just prefer the most efficient flashlight, not the most efficient for the manufacturer to produce.
This is a pretty poor paint picture but the idea is good, traditional square led on the left and round led on the right. I'm sure all that extra area will produce a lot more lumens.
And if you want to maximise throw instead of basic luminous efficiency then a smaller die with the same current (assuming similar efficiency per unit of area) will give much higher surface brightness..
This is true, but to be honest, the flashlight market isn’t even a blip on Cree’s radar, general lighting is. The goal is to replace the incandescent bulb and fluorescent lighting.
In the case of flashlights 99% of the time the leds sit at the bottom of the circular hole in the reflector, to fill that hole would make more light rather than just make it bigger to fit a bigger square led, then you could still fill in around it (round led) and produce more again.
Either way, 2 types, 10 types, 573 types.. I don't really care, the more choice the better.
The more competition the more they will work harder to make better leds.
Yes, true again. I don’t think there are any LED manufactures that are really focusing on the flashlight though. In comparison to the lighting market it is a small segment. I mean, all these LEDs are targeted towards things other than flashlights, they just happen to work in that role as well.
