for RD series, there is a option called ”Boot Pow”,which means when you power on the device,the output will be turned on automatically,but it only applies on the normal red terminal,the battery charging terminal doesn't have this function for saftey reason
IML delivery in 3 days (during the May holidays), packed perfectly. The packaging of the module itself pleased me. I will check for heating in stress mode, pulsations, and the accuracy of the readout meters. look for Crazy_Geeks on YouTube
Arrive faster than expected, well packaged and operates as expected. Took serveral days before it shipped and tracking didn't work but it arrived in less than 2 weeks from order so very happy.
hello, I need to say it once again, when using DPS or DPH series power supply to charge battery, please follow this: 1. check the if the connection is right, 2. set the suitable voltage and current, 3. turn on the output. the connection is very important
but for RD series power supply, as long as you use the battery charging terminal, it has no problem, even though you connect the battery in the wrong way, it will use icon to show you that the battery is not connected and will not output
(usually the shipping time is about 20-30 days, but for some country, because there is no direct flight, it will go other countries first and stuck there if there is no enought flight)
I’m reading this to mean that they do not sell a power supply capable of allowing the 110v version make full power, only at 220v can you get the full 18A.
Yeah I went back and checked everything. Didn’t find the answer. You said it could not do 18A at 110v, so I asked what was the max output at 110v.
We mostly use 110v - 120v in the USA. Not 220v.
I’m sure if I knew Jack about electronics I could figure it out. Electronics dumb dumb here.
NP. I can ask someone over at the electronics forum if you don’t have that answer.
Thanks
the next promotion should be 618 promotion, but it starts from June 21th, and ens at June 25th, if you have our products in your cart or wish list, you can check the price at that time
