Headlamp without magnet head or tail
5 posts / 0 new
Porchlight
Porchlight's picture
Is there a headlamp on the market for 18650, onboard charging, without magnetic tailcap?
Should I drop the onboard charging in favor of using batteries with onboard charging? How well do these batteries with usb charge ports work & do they fit in the lights ok?
I’m trying to find the lightest weight headlamp in 18650 compatibility to fit my criteria. Not having much luck yet except ZL H604 with a usb charging battery.
Sunnysunsun
Sunnysunsun's picture
Last seen: 14 min 13 sec ago
You can get an sp40 without a non-magnetic tail cap if you ask them. I don’t think ZLs fit long batteries like button tops or magnetic charging ones.
Parametrek
Parametrek's picture
Last seen: 3 weeks 6 days ago
Yeah there are a bunch. The Skillhunt H03 RC or H04 RC are probably the best option. They ship with a magnetic tail but the magnet is easy to remove.
If you want something that takes a normal USB plug then consider the Sofirn D25S or Thrunite TH30.
Try the largest, fastest, most flexible flashlight search engine: parametrek.com
58 brands, 2773 models and still growing!
NEW: US battery database and European battery database
NeutralFan
NeutralFan's picture
Last seen: 1 hour 10 min ago
How about the BORUiT D10? For less than $15 it includes USB charging, it’s lightweight, very bright, and nice firmware. And easy to mod if you want a different LED. I’m very happy with mine.
I’d rather use my flashlight around the house than turn on the lights.
Porchlight
After researching more about them, the Sofirn D25S almost works. The weatherproofing isn’t enough but fixing that & if I could get faster charging speeds, I think I’d try it. Is there any way to mod the charging to 1.2A charge rate so it finishes in 2.5hrs like the TH30? The SP40 & TH30 don’t have the right/enough low modes for me. I’d be using up extra battery all the time.
The Skilhunt lights are a good compromise, but it would be better to have a regular charge cable in case of damage or loss during continuous everyday use. The charging speed sucks compared to the Thrunite anyways.
