I’m reading this to mean that they do not sell a power supply capable of allowing the 110v version make full power, only at 220v can you get the full 18A.
Yeah I went back and checked everything. Didn’t find the answer. You said it could not do 18A at 110v, so I asked what was the max output at 110v.
We mostly use 110v - 120v in the USA. Not 220v.
I’m sure if I knew Jack about electronics I could figure it out. Electronics dumb dumb here.
NP. I can ask someone over at the electronics forum if you don’t have that answer.
Thanks
the next promotion should be 618 promotion, but it starts from June 21th, and ens at June 25th, if you have our products in your cart or wish list, you can check the price at that time
Compared with low current version, we found that most customers prefer higher current version RD6018 (18A), but they also want us to release 5 digit version, we will release RD6012P later, for other model, we need to judge the situation(materials)
the inverter has great performance. in conjunction with a computer via USB for extended possibilities. the quality of the power supply is surprisingly good. in the future I will open up buying another one.
Yeah. I just bought some cool 18650 battery holders off of ebay that can hold 4 cells and they have solder tabs so I can wire them in parallel or series and charge 4 of them at a time with the RD6018 any way I want. I could combine more and charge as many 18650’s at one time as I care to….up to the 18A limit.
The battery charge feature is nice and shuts it off automatically at the preset voltage.
I liked my first RD6018W so much I just had to have a second one.
It seems I find 1000 uses for a good power supply.
there are 2 PSU you can choose for RD6018, you can choose the one suitable for you
800W PSU can let RD6018 output 18A, but it cannot let RD6018 full output because it is lower than the max output power of RD6018(1080W)
1000W PSU is 68V 17A output at 220V AC input, it can let RD6018 full output, but it is 68V 14.7A (about 1000W) at110V AC input, so it cannot let RD6018 full output, pleaseset the power limit to 950W in RD6018 setting. It can be placed in S800 case.
