Is there a headlamp on the market for 18650, onboard charging, without magnetic tailcap?
Should I drop the onboard charging in favor of using batteries with onboard charging? How well do these batteries with usb charge ports work & do they fit in the lights ok?
I’m trying to find the lightest weight headlamp in 18650 compatibility to fit my criteria. Not having much luck yet except ZL H604 with a usb charging battery.
How about the BORUiT D10? For less than $15 it includes USB charging, it’s lightweight, very bright, and nice firmware. And easy to mod if you want a different LED. I’m very happy with mine.
After researching more about them, the Sofirn D25S almost works. The weatherproofing isn’t enough but fixing that & if I could get faster charging speeds, I think I’d try it. Is there any way to mod the charging to 1.2A charge rate so it finishes in 2.5hrs like the TH30? The SP40 & TH30 don’t have the right/enough low modes for me. I’d be using up extra battery all the time.
The Skilhunt lights are a good compromise, but it would be better to have a regular charge cable in case of damage or loss during continuous everyday use. The charging speed sucks compared to the Thrunite anyways.
