✌ LUMINTOP CL2 4*SST20 NW 630lm Type-C Camping Lantern Group Buy - ALIVE!!!
118 posts / 0 new
freeme
freeme's picture
Last seen: 1 hour 44 min ago
LUMINTOP CL2 Camping Lantern
1-4x 14500/AA Type-C Rechargeable
Lumintop CL2 lantern grid
This NOT LT1 direct competitor.
No need to be too critical on its design and performance.
There are tons of people out there who just want a simple light.
I used Obulb almost everyday and it only has a non-replaceable 630mAh battery.
cool
Our Test Results
 Lumintop CL2 AA Brightness
Do account 10-15% margin of error for all our measurement values.
Group Buy Price: $XX.99
Freeme's Coupon:  To Be Announced
©freemex1thedeals.com
Can't wait for our reply??
Price:  $40.99
Coupon: FATHERSDAY
 1thedeals-lumintop-cl2-blf-preview2
FEATURES
  • Utilizes Luminus SST20 NW LED  with a lifespan of 50,000 hours
  • Powered by 1 to 4 AA or 14500 rechargeable Li-ion battery
  • max 650 lumens output
  • Super long runtime up to 28 days in moon mode (AA)
  • USB type-C rechargeable,max 2A charging indicator (does not support AA/NI-MH charging)
  • Reverse protection guard against improper battery installation
  • side switch for easy and one-hand operation
  • Lock out function to prevent accidental activation
  • Built-in battery indicator and mode memory function
  • Standard tripod socket and hands-free hook
  • Size: 137.5*55*39mm
  • Net weight: 222g without batteries
  • IP68 waterproof and dustproof protection
Operation Instruction
ON/OFF/Mode change: One click for ON, another click to change
outputs, press and hold for 1 second for OFF.
  1. Turbo: Two quick clicks when the light is on, one-click will return to general mode.
  2. Moonlight: From OFF, press and hold the switch for 2 seconds to enter the Moonlight mode
  3. Blink modes: From Moonlight, two quick clicks can enter Strobe, another click to cycle SOS-Beacon-Strobe.
  4. Lock-out: Press and hold the switch for 5 seconds from OFF will enter the lockout mode, press and hold another 5 seconds to unlock.
ANSI/NEMA FL1   Moonlight Low Med High Turbo Strobe/SOS/
Beacon
Output 14500 2LM 10LM 160 LM 400 LM 650 LM 400 LM
AA 2LM 5 LM 20 LM 50LM 90LM 50 LM
Runtime 14500 20 days 15h 2h 40m 4M+2h 10m 1m 50s+2h 10m /
AA 28 days  48h 22h  10h+1h 30m 5h 3m /
Distance 46m
Intensity 135cd
Impact Resistant 1m
Waterproof IP68 (underwater 2m)
Notice: The above approximate parameters are lab-tested by Lumintop by using four 3.7V/750mAh 14500 Li-ion cell, and four 1.5V/2000mAh Alkaline cells, it may vary due to the difference of environment and batteries.
1thedeals lumintop cl2 lantern 2
1thedeals.comyoutubeAstroluxNealsgadgetsolight
Edited by: freeme on 06/16/2021 - 08:16
JaredM
JaredM's picture
Last seen: 1 day 3 hours ago
NiMH support? Emitters? UI?
freeme
freeme's picture
Will update over the weekend. There will be high CRI LEDs for sure.
toddcshoe
toddcshoe's picture
Last seen: 1 hour 48 min ago
I’d be in for 2 or 3. NiMh support would be great but even without it, I’m in.
"Everywhere I go, there I am"
Scallywag
Scallywag's picture
Last seen: 13 hours 26 min ago
Gonna be good when someone charges their alkaleaks with usb-c.
Not interested. 4 14500s won’t even match a single 21700 for runtime, and barely best a 35E.
taenzerwalze
Last seen: 1 week 2 days ago
I’m interested in one lantern.
TexasToasted
TexasToasted's picture
Last seen: 7 hours 42 min ago
If it has a strong magnetic tailcap, I’ll be interested.
TexasToasted
Agreed, but AA cells will make this a great gift for grandkids Thumbs Up
Hmm… Does “1-4× 14500/AA Type-C Rechargeable” mean this light works with 14500 Lithium Ion, and AA Alkaline, and AA NiMh rechagrable, or does it just mean AA size Lithium Ion cells?
llk
Last seen: 22 hours 38 min ago
Interested in one.
weklund
weklund's picture
Last seen: 1 hour 3 min ago
Interested in 4.
... Happy Landings ...
Gunga
Gunga's picture
Last seen: 1 hour 36 min ago
Interested if it uses AA. Not just 14500
freeme
freeme's picture
Both supported but output is most probably lower for AA.
ShyOne
ShyOne's picture
Last seen: 29 min 41 sec ago
I am in for at least a couple. ✅
freeme
freeme's picture
Not sure if stand is included but I can confirm that full specs should be ready by next week.
flightless22
flightless22's picture
Last seen: 4 hours 7 min ago
I’ve been asking for LT1 based on Sofirn SF11 for a while. I’m very interested. I hope this uses Anduril 2 with tint ramping.
Scallywag
Scallywag's picture
Freeme I get that it’s not supposed to compete with the LT1 but when the appearance is so similar, comparisons will happen. I’m interested to see the specs (and details like if the LEDs are on the top or bottom).
Hopefully the charging circuit has a cutoff so that it won’t try to charge things below 2.0V or something so nobody blows up AAs in it.
wolfstyle
Last seen: 6 hours 14 sec ago
Interested
iamlucky13
Last seen: 1 day 23 hours ago
I have a hunch it will not charge NiMH batteries or anything else below a certain threshold that would indicate a healthy lithium-ion battery is installed. This would confuse many users, but would make sense unless it has a fairly sophisticated charging circuit.
I’m not jumping in yet, but I will watch this thread for more details.
EvlDude
Last seen: 4 weeks 13 hours ago
Hmm, not sure. Waiting to see specs.
Itsme
Last seen: 1 week 6 days ago
Interested in 2 if they will run on AA NiMH
Dkf1998
Last seen: 9 hours 5 min ago
Interested
firstcipher
Last seen: 6 hours 33 min ago
Interested
California_Prepper
Last seen: 4 weeks 1 day ago
Interested
bansuri
Last seen: 3 hours 31 min ago
Interested
raccoon city
raccoon city's picture
Last seen: 4 min 53 sec ago
Wow, if this runs on NiMH AA, that's excellent for people that don't like Li-Ion.
I am not interested, but I bet it'll be a great lantern.  :BEER:
Agro
Agro's picture
Last seen: 14 min 33 sec ago
Probably won’t buy but I’m interested.
Funzel67
Last seen: 2 hours 22 min ago
I would be interested if it also charges Nimh.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 1 day 5 hours ago
Any information about the UI, yet?
Flashbug
Flashbug's picture
Last seen: 6 hours 41 min ago
I’m interested .
Helmut.A
Helmut.A's picture
Last seen: 1 week 3 days ago
interested
cloggy
Last seen: 1 hour 15 min ago
Interested, may well buy- spec. dependent.
cloggy
