Any good 16340 Hosts?
What is a 3P?
Could you please link to the clone?
Check your PM :+1:
I am not sure if you are still searching , but take a look “blast from the past” (yeah, Roxane is an “old” brand):
https://www.aliexpress.com/item/1005002372874591.html
https://www.aliexpress.com/item/1005002372613180.html
Assuming a ’123 will keep a more or less steady voltage, you just gut the driver and stick in the appropriate-value resistor.
The little Thorfire KL02 doodads (also made for ’123s ’though 16340s will run hot) do exactly that, “bead” type LED and a resistor on one contact-board, that’s it.
Some dewd was selling them on fleabay 10 for 20bux or something, obscenely cheap. I got 2 duds in a 10pak, but it was still worth it.
There’s space for a 10mm MCPCB. I’m using an eagtac 16340 in it (short and protected) to have a small lantern.
Yeh, I didn’t want to cook them nor run down a Li cell to nothing, couldn’t find my real ’123s, so I got a set of those 3V Li-based converter cells.
https://www.aliexpress.com/item/4000389793969.html
Thought about snagging this little thing… but I ain’t got no 16340 cells. Might pick one up if Vapcell T6’s turn up at a reasonable price.
You chicken.
WOWTAC W1 $19.99
The bezel is glued, besides that it’s a decent light with just the led swapped.
The new Sofirn SC21 will be slightly more expensive but a whole different beast.
https://sofirnlight.com/products/sofirn-sc21-mini-flashlight-rechargeable-flashlight-1000-high-lumens-small-but-super-bright-with-16340-batteryinserted-magnetic-tailcap-for-edc-dog-walking-jogging
Maybe even a S1R competitor.
That looks very interesting and the price is reasonable. Thumb size and egg weight is a good decision.
I wish sofirn would go with Anduril 2 or at least make some tweaks for the ramping firmware to move slower for the lower output and faster for higher output.
Dunno if these were the ones, but someone here was all gaga over these or similar ones. 3bux a pop, go crazy…
https://www.aliexpress.com/item/32857438398.html
Ain’t got any, so dunno from any firsthand experience with ’em.
I think I’d need to know first if egg weight is extra-large or jumbo or small or what. I’m not quite sold on it.
Platypus, chicken, or hen?
Very cool. I’m tempted, but for just 11mm extra length, 5mm extra width, and few meager grams of weight…
More output, better runtime (1200mAh 18350), Anduril…the only thing it’s missing is a sweet deep carry reversible clip like that SC21.
I’ll probably snag one anyway because “Sofirn”, and the price is crazy reasonable. TBH, I haven’t been disappointed in one Sofirn product I’ve purchased, and if I was compelled to go down another li-ion cell size rabbit hole, that might trigger it.
…sorry….and no freeloading…maybe this a possibility?
Thrunite BSS bundle
It’s cute but I think, between my D25C TI, S1 (original), and V10R Ti+, I’m probably done with 16340s. I’d need a real compelling reason to carry something else in the size class.
Chicken! lmao
Cheep-cheep-cheep-cheep-cheep!
Yeah, that’s not gonna land…
That thrunite deal ain’t bad. That little headlamp is a handy dandy
The Thrunite/Wowtac W1 lights are good budget lights.
I like the driver and UI, but they do need a LED swap.
The bezel is glued but I’ve been able to remove it with some heat and grippy gloves.
Now I need to decide which LED.
I also like the headlights in that bundle linked above. They also need a LED swap. I haven’t opened one of those yet, but I will.
FB
