This photo isn't mine, but I eat a massive quesadilla on most days.
I use 8 ounces of Pepper Jack cheese, 5 ounces of flour tortilla, almost an ounce of pepperoni, maybe an ounce of diced green chilis, and quite a bit of hot sauce.
The recipe is completely my own.
That's about 15 ounces of food.
Most people don't put pepperoni in their quesadillas, but it tastes good to me, and it's easy to work with.
It's the only food that I put together and cook.
I know that it isn't very healthy, especially with all of that cheese, but I don't plan on quitting unless my doctor tells me to.
My cholesterol and triglycerides are a tiny bit high even though I take several things for them, so I could be doing a lot worse.
One big honkin’ chicken-breast cut lengthwise into 4 strips (more surface area, less “thickness”, more even cooking). Brown ’em in the pan, set aside on Al foil.
Half-can of cream-o-chicken soup, little bit of water, bring to a boil in the pan and scrape up the fond.
Put back the chicken and cook through.
Add the juice of a whole lemon, let that cook a while
Taste and make sure it’s “fresh” and “lemony” and “citrusy” without being “sour”. If so, a little bit of sugar cuts the sourness. Don’t overdo it, though, else you’ll have lemonade chicken and not lemon chicken.
Sprinkle parsley flakes over it. Black pepper to taste, too.
Devour.
You can make rice separately, or as I took to doing the past coupla times, use a whole can of COC soup with lots more water, and dump a cup of long-grain rice (uncooked) into it. Make sure it cooks looong enough unless you want al dente rice.
Yesterday I wanted something different, and aside from cooking up a huge corned-beef (did that last week, Good God was it delicious, and just cabbage, not even potatoes, carrots, onions, nuttin’), all I had was a package of chicken drumsticks’n’thighs.
Broiler-pan lined with Al foil.
Slice up onions, make that the bottom layer. Salt profusely to extract the water. You want them to boil in any juices, else they dry up but still have that pinchy “raw onion” taste that’s just nasty.
Small chunks of potato, make that the next layer. Best if they can stay above water so they cook through but still develop a “skin” that’s just on the chewy side.
Drownd the chicken parts in Adobobobobo seasoning. Lay the chicken on top of the other stuff, cover the pan in more Al foil to essentially let it steam.
Cook at 350-375… a while. 45min might do it, kinda depends. Think I left mine in close to an hour, ’cause the chicken was frozen and I did “brine” them in hot water (changed 2-3 times) to try thawing them out fast, but the insides were probably still cold.
I measured 175 internal temps when I pulled ’em from the oven and took off the top layer of foil. Still quite “beige”, even though cooked-through inside.
Crank up the heat to 475-500, put back for 10-15min or so to develop some color.
Take out, let ’em rest a while, devour.
Even though technically “overcooked”, they came out perfectly. Tender without being rubbery, certainly not dried out in any way. At least once before they were at/over the minimum 165, but poking with a thermometer, they oozed some blood, so I tend to cook ’em to at least 175-180 anyway.
Took me some trial’n’error, mixing onions/potatoes together vs layering them, being “decorative” by putting some onions on top of the chicken, etc. Nope, the layers work best. Onions cook in the broth, potatoes cook exposed to air, chicken “steams” most of the way while resting on the potatoes.
Oh, and foil-lined means the pan required near-zero cleaning after. Some Adobobobobobo powder found its way between foil and pan, but no liquid or grease or anything.
Speaking of which, it’s almost 15:00 and I still didn’t have “breakfast” yet.
Lots of great tasty entries for sure, but for me this time it has to go to maniakman and the Gene & Judes Hot Dogs. That would be high on my list if I ever visited the USA. I like ‘dirty’ foods like this.
Will be making Lightbringers lemon chicken too sometime. Those Taco’s look great too!
Thanks G0OSE!
How about some pictures of human designed things that just can’t be improved upon … no matter how much we try….(i.e. designs that withstood the test of time)…
