Exciting news! XTAR T2 pocket light was just released.
View more details on website:
Main features of T2 below:
*Max output 650lm, beam throw 65m
*3 lighting levels for standard mode, with runtime max 4.2h
*3 lighting levels for moonlight mode, with runtime max 45h
*Hidden strobe mode for self-defense and emergency
*Type-C port charging anywhere & anytime
*Switch lock function to avoid accidental turn on/off
*Magnetic tail cap & removable pocket clip
*Memory function to go to its previous lighting level
*Reliable and strong aluminum alloy body
*Mini size with length 7.5cm & weight 29.5g
shame not use atleast 10440 battery more common…usb c cover in this type of light really not needed, better have more protection from water and liquids.
Whats the UI? Why can’t manufacturers list the freakin’ UI on the product page. It’s an e-switch, so there’s no excuse not to have a good UI with shortcuts to moon and turbo. The form factor looks good, silly battery aside. Offer it with a good high CRI LED or at least don’t glue it shut so we can swap it ourselves.
controversal model. built in charge + replaceable battery is strong side. But WHY 10380? it totally has no advantage over 10440. i hope UI is not sort o of sh*tfires.
suppose such castrated battery will be deal killer for lots of people.
When the light is off, long press the switch to turn on, and single click to change lighting levels for standard mode: Low /Mid / High. Click twice to enter moonlight mode, and single click to change moonlight level: Low /Mid / High. Click 3 times to enter Strobe mode. And long press to turn off.
For lock function, click 5 times to switch-lock, and green indicator blinks once it locks; Click 5 times again to unlock, and enter standard low mode.
