2PCS SMILING SHARK 657 Mini LED Flashlight
1*LED / 3-mode / 80LM / pure white / 1*18650 / 1200mAh power bank / IPX6 waterproof
Authentic Fenix PD35 V2.0 LED Flashlight
1*Cree XP-L HI V3 / 6-mode / 1000LM / white light / 1*18650/2*CR123A
PD35 V2.0 is a handy and delicate flashlight. Fitted with Cree XP-L HI V3 LED, it delivers a max output of 1000 lumens and a far-reaching distance of 250 meters. This compact but tough flashlight features five output levels, plus instant strobe, battery level indication is fitted as well. Powered by one 18650 rechargeable Li-ion battery, it is also compatible with cold-resistant CR123A battery. The dual switches design - tactical tail switch and metal side switch, offers rapid and user-friendly operation. All these highlights make PD35 V2.0 very suitable for military use, policing, outdoor exploring, emergency lighting and even more.
Head diameter: 25.4mm
Tube diameter: 23mm
Tail diameter: 25.4mm
Working voltage: 1.8-3.7V
Beam range: 250 meters
Boot-up battery level indication and low-voltage warning
Digitally regulated output maintains constant brightness
Reverse polarity protection, protects from improper battery insertion
Anti-roll and anti-slip body design
Tactical tail switch features instant activation
Metal side switch for output selection
Outdoor USB Rechargeable LED Headlamp
1*Cree XM-L2 + 2*LED / 11-mode / 750LM / white+blue+red light / 1*18650 / 180β rotatable lamphead
What an exceiting News! FastTech 9th Anniversary is coming! To celebrate the 9th anniversary of FastTech, weβll prepare a discount of 15% Site-wide and there are more surprises waiting for you! Are you ready?
ββββββββ- Anniversary Site-Wide Coupon βββββββββββ
Offer: Site-wide 15% off
Valid Date: Jun 2, 2021 (UTC-6)
Coupon Code: FASTTECH2021
Click here to know more information of the anniversary promotion: FastTech 9th Anniversary 15% off Site-Wide
Does order history gets deleted after a few years? Paypal/ebay does the same thing itβs just an inconvenience.
Yes, customers maybe canβt find orders placed a few years ago in their accounts. If you need to check any of your old orders, you can contact us via ticket, our customer service representatives will try the best to provide the order information to you.
SMILING SHARK ES03 EDC LED Keychain Flashlight
3*LED / 6-mode / 3000LM / pure white / 1*20350 / IPX8 waterproof / multi-stage heat dissipation / crush & drop resistant
F401 3*LED 6-Mode 5000LM LED Flashlight
pure white / 4*18650 / IPX5 waterproof / OLED display / stepless dimming / power bank function
6-mode: Long press for 3 seconds to turn on. Strong light-medium light-low light (double click) turbo~~(single click) strobe~~(single click) low light single click to shut down
Any mode stays for more than 8 seconds, it is shutdown
Long press the switch after power on is the stepless dimming function, the light flashes twice when it is adjusted to the brightest, and twice when it is the weakest
Temperature protection and short circuit protection
Automatic power off under low voltage
F402 3*LED 6-Mode 10000LM LED Flashlight
pure white / 8*18650 / IPX5 waterproof / OLED display / stepless dimming / power bank function
SMILING SHARK X28 LED Flashlight
1*LED main light + 1*COB side light / 3-mode / 135LM / pure white / Micro-USB rechargeable / 360β rotation / IPX6 waterproof / w/ hook
2PCS SMILING SHARK 617A LED Flashlight
1*LED / 3-mode / 240LM / 1*18650 / USB rechargeable / power bank function / IPX6 waterproof
2PCS SMILING SHARK 103A LED Flashlight w/ Focus Zoom
1*LED / 3-mode / 1200LM / pure white / USB rechargeable / IP65 waterproof
SMILING SHARK E512 LED Flashlight w/ Focus Zoom
1*LED / 3-mode / 1500LM / pure white / 1*5500mAh 26650 / USB rechargeable / IPX6 waterproof / power display
Wow! Discount of 15% Site-wide for the 9th anniversary of FastTech has started. Seize the big discount promotion. Shop nowβ https://www.fasttech.com/
ββββββββ- FastTech 9th Anniversary Giveaway βββββββββββ
Offer: Mega Prize for 13 Winners
Valid Date: Jun 7, 2021 (UTC-6)
Quick question?
I already ordered, but had to pull a few small items from what I wanted.
I ordered a bunch of parts that I needed (well, wanted ), and the only shipping option on checkout was 7bux, almost ΒΌ of the order! So I checked my cart, and almost everything was marked βfree shippingβ, but 2-3 werenβt. One of those was a small pack of Hall-effect sensors, total weight maybe 2-3 paperclips (oddly, today it shows as free shipping!) and another was a small pack of bare βbeadβ type LEDs, so itβs not as if the items were bulky or heavy. In fact, they were quite light compared to some other items.
Anyway, even 1 item not marked as βships free to the USβ in the cart triggers the 7buk shipping option.
Like I said, I ordered most of what I wanted, but had to drop those 2-3 small items so it wouldnβt trigger the pricey shipping option. Any way around that in the future?
Solar + USB Powered MTB Bike Bicycle LED Front Light
2*LED / 4-mode / 400LM / pure white / 4000mAh power bank / IPX4 waterproof / w/ 130dB horn (5-sound) / 4-level power indicator light
1*LED+1*COB 7-Mode 800LM LED Flashlight
pure white laser & red light / 1*18650/1*26650 / power bank function / IPX4 waterproof / power indicator light
Head diameter: 68mm
Tail diameter: 35mm
Indicator light: 4 power indicator lights 25β50β75β100
SMILING SHARK E513 Four-color Atmosphere LED Flashlight w/ Focus Zoom
4*LED / 5-mode / 800LM / pure white+RGB / 1*18650 / w/ diffuser filter / built-in 4 wicks / removable light sleeve / water resistant
Head diameter: 30mm, Voltage: 3.7-4.2V
