PD35 V2.0 is a handy and delicate flashlight. Fitted with Cree XP-L HI V3 LED, it delivers a max output of 1000 lumens and a far-reaching distance of 250 meters. This compact but tough flashlight features five output levels, plus instant strobe, battery level indication is fitted as well. Powered by one 18650 rechargeable Li-ion battery, it is also compatible with cold-resistant CR123A battery. The dual switches design - tactical tail switch and metal side switch, offers rapid and user-friendly operation. All these highlights make PD35 V2.0 very suitable for military use, policing, outdoor exploring, emergency lighting and even more.
Head diameter: 25.4mm
Tube diameter: 23mm
Tail diameter: 25.4mm
Working voltage: 1.8-3.7V
Beam range: 250 meters
Boot-up battery level indication and low-voltage warning
Digitally regulated output maintains constant brightness
Reverse polarity protection, protects from improper battery insertion
Anti-roll and anti-slip body design
Tactical tail switch features instant activation
Metal side switch for output selection
What an exceiting News! FastTech 9th Anniversary is coming! To celebrate the 9th anniversary of FastTech, we’ll prepare a discount of 15% Site-wide and there are more surprises waiting for you! Are you ready?
Yes, customers maybe can’t find orders placed a few years ago in their accounts. If you need to check any of your old orders, you can contact us via ticket, our customer service representatives will try the best to provide the order information to you.
6-mode: Long press for 3 seconds to turn on. Strong light-medium light-low light (double click) turbo~~(single click) strobe~~(single click) low light single click to shut down
Any mode stays for more than 8 seconds, it is shutdown
Long press the switch after power on is the stepless dimming function, the light flashes twice when it is adjusted to the brightest, and twice when it is the weakest
Temperature protection and short circuit protection
Automatic power off under low voltage
I already ordered, but had to pull a few small items from what I wanted.
I ordered a bunch of parts that I needed (well, wanted ), and the only shipping option on checkout was 7bux, almost ¼ of the order! So I checked my cart, and almost everything was marked “free shipping”, but 2-3 weren’t. One of those was a small pack of Hall-effect sensors, total weight maybe 2-3 paperclips (oddly, today it shows as free shipping!) and another was a small pack of bare “bead” type LEDs, so it’s not as if the items were bulky or heavy. In fact, they were quite light compared to some other items.
Anyway, even 1 item not marked as “ships free to the US” in the cart triggers the 7buk shipping option.
Like I said, I ordered most of what I wanted, but had to drop those 2-3 small items so it wouldn’t trigger the pricey shipping option. Any way around that in the future?
Reflector diameter: 1.8cm
Head diameter: 2.4cm
Tube diameter: 2.4cm
Tail diameter: 2.4cm
Beam range: 50-100 meters
Lanyard length: 13cm
Voltage: 3-4.2V
To switch mode group: Switch to low mode and wait for 5-10 seconds. As soon as you notice the flashlight automatic blinking, turn off and then turn on, the mode group is then toggled
