How are your oldest eneloops doing?
53 posts / 0 new
Bort
Bort's picture
Last seen: 1 min 55 sec ago
no voltage necessary
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
MountainKing
I did a test (discharge-charge)on my beat up eneloop and it came out at either 1728 or 1782 MAH something….
I will do a 2nd test, which will test the eneloop for max capacity.
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
Hobbyfotograaf
Last seen: 4 months 10 hours ago
I have switched to low selfdischarge batteries in 2008. The first lsd batteries were GP Recyko’s, and these are still working perfect.
Since the i bought several different lsd batteries (Aldi Top Craft, Tronic from Lidl, and Eneloop), only one AAA Top Craft battery died, but that is probably because it was completely discharged for a few months.
All these batteries are Always charged in the Maha MH-C9000, the ones that are nog used get a refresh/analyze every year (even the oldest batteries have almost the same capacity as when they were new).
The AA batteries are charged with 1000mA, the AAA batteries with 300mA.
Don’t discharge the batteries completely, and don’t charge them with high currents, because the heat will kill them.
Use a charger that charges every battery separately, and don’t use batteries with different capacity together (check the capacity with a decent charger like the Maha).
Rockenrooster
Last seen: 7 hours 17 min ago
I’m curious to see how everyone’s eneloops are holding up now…
I don’t have any “old” eneloops.
Oldest batteries I have are 5 year old Rayovac lsd, which still seem to do ok today.
ShyOne
ShyOne's picture
Last seen: 1 day 21 hours ago
My oldest Eneloops are from 2006 & still going strong. ✅
voip
voip's picture
Last seen: 4 months 5 hours ago
My oldest Eneloops BK-3HCCE (Eneloop Pro, Made In Japan) are about 8 years old and are powering a brutal device for batteries: Wahl hair clippers. So they had to direct drive the clippers, travel through various countries, go through cold and very hot climates, and get a lot of vibration and hits.
They still run fine, capacity is almost as high as new.
jon_slider
jon_slider's picture
Last seen: 2 hours 19 min ago
some of my 5 year old AAA eneloop pro are half as bright in my Lumintop AAA Tool, as my same age eneloop..
so I bought a few more non-pro
I cant measure capacity, but I do have a light meter, so I can compare different battery outputs in the same light.
zoulas
zoulas's picture
Last seen: 8 min 32 sec ago
11 years. decent shape.
def_nvar
Last seen: 1 week 11 hours ago
I have 4 gen1 AAA sanyo eneloops manufactured 12-2007, used for high current (flashlight) but infrequently, so definitely <50 cycles.
Charged in BC700, always at 200mA before I knew better :/
Capacity still seems fine, the worst one has 85% left but all of them have developed high internal resistance.
They can only be used in low-drain devices now but 13.5 years is beyond impressive.
Sadly I have no meter for measuring the internal resistance.
cayman
Last seen: 4 months 3 days ago
My old eneloop are still fine, about 6 years old. Mostly used in RC toys and flashlights.
They hold up fine, I think.
worth the money.
snakebite
snakebite's picture
Last seen: 1 week 5 days ago
i have some first gen from 06 in a solar light.
recently tested at 1781-1784 1a. great for a set in use cyclically every day for 10 years. ir 60mohm. new are around 30. i just opened a set of duraloops from 11. 1.31v all 4. out of the pack they gave 1123-1125 1a
after 2 cycles i got 1887-1891 @1a
ChrisGarrett
ChrisGarrett's picture
Last seen: 12 hours 19 min ago
9/2011.
Chris
chops728
Last seen: 40 min 42 sec ago
This thread had me wondering about some of my Eneloops— I tested some random singles I had at 800 ma discharge
Sanyo 11/13 ——- 1773 / 1790
Panasonic 5/16 ——— 1585 / 1773
jon_slider
Bort wrote:
How old and how like new are your oldest eneloops performing? Also estimate the number of cycles on them and how much they were abused.
I do not understand how to measure batteries performance, and I do not understand the meaning of several of the posts with IR numbers in them
can you explain what measurements give what info, what does IR tell you?
does higher IR correlate with Lower Lumen output?
my experience is after 5 years of light use, zero abuse, my Eneloop Pro produce half as many lumens in my aaa Tool… than they did when new. but I dont know how to measure IR, so I dont know if those two factors, higher max output, and Lower IR, are correlated
factual, measurement based education welcome..
can you summarize this thread, to tell me what you learned?
ChrisGarrett
Batteries/cells develop high internal resistances over time and as a result, they tend to self-discharge more, don’t output the same current as when new and become harder to charge, to the point that many consumer chargers will reject them due to crappy power supplies. Some dumb chargers can force charge high I.R. batteries, but it’s a losing proposition.
Analyzing chargers with internal I.R. functions are flaky at best and the ‘number’ should rarely be viewed as gospel, but it does give the user a sense for comparison purposes.
Chris
jon_slider
ChrisGarrett wrote:
develop high internal resistance… don’t output the same current as when new
thank you
does high IR also reduce runtime?
I cant measure IR, but I can measure lumens. I dont usually worry about runtime, so have not checked…
though my old eneloop pro AAA in my Lumintop Tool, dont reach 50% of maximum anymore, the low and medium modes work normally..
so I think people with old batteries in low drain devices like remote controls, or flashlights with low output levels, will not notice when an old eneloop is no longer able to support maximum output, since those low drain applications dont have such a high demand for power. Does that make sense?
d_t_a
Last seen: 18 hours 41 min ago
I have some really old Eneloop white (circa 2007-2008), and back then I didn’t know how to charge them so they last longer — I bought a GP 1-hour rapid charger to charge them since I thought a fast charger will be good when I need batteries to charge faster (my only other NiMh charger back then was a very slow ~8-12 hour standard charger which I find too slow).
I recall the NiMh batteries do get very hot while charging, so these likely reduced those old Eneloops.
When I got the SkyRC MC3000 about 2 or 3 years ago, using the DC IR resistance check function, they read ~2000-3000+ mOhms.
Using the YR1030 AC IR resistance test, these also have like 5Ohms (ie. 5000+ mOhms).
A new Eneloop I bought in the last few years (not abused / charged at very high charge current), the DC IR from MC3000 will read below 100mOhms
YR1030 AC IR of the new Eneloop will be somewhere from 20-30mOhms.
When used in a flashlight, eg. Tool AA: – the ‘old very high-resistance” Eneloop won’t go to High mode (High will drop to Medium, which is a low-brightness “Medium” brightness) (there is a slight brightness difference between Low and Medium) ( I don’t have a way to measure lumens though)
– new Eneloop works fine with Tool AA, there is a difference between Low and Medium and High , which are distinctly different brightness
In terms of capacity, I believe my old Eneloops still have fairly good capacity providing the discharge current is very low (eg. below 0.10A). Any higher than 0.1A and the voltage will drop a LOT.
Unlike the newer Eneloops which work well even at higher current like 1.0A
jon_slider
thanks!
that is very helpful info
it provides a way to know when a battery is failing, without measuring IR, and without measuring lumens… if the battery can no longer support a normal High Mode.
I have the same result with a Tool AAA, the lower modes still make the same lumen output as a new eneloop, but the high mode is only slightly brighter than medium, with my old tired eneloop
jmpaul320
jmpaul320's picture
I have two sets from 2012 that probably have over 100 cycles on them that are still working fine.
Haven’t noticed any reduced runtimes on my d40a.
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
chops728
Wow one of the members from when I first joined BLF —- Good to see you’re still around
aginthelaw
aginthelaw's picture
Last seen: 1 day 20 hours ago
Just found my 2 eneloops from 2008 in my nieces old point and shoot. I’ve been reconditioning them on a maha they give me about 40 minutes of light on a 2 aa xeno es2 on med. after a few minutes on high I left it on med then 5 minutes later they refused to go on high. They might be coming back to life
never fear shadows…it means a light shines nearby
def_nvar
my gen1 AAA eneloops from 03/2007 have between 850 and 2880mOhm, maybe 50 cycles total
curiously my gen1 AA eneloops from 02/2009 have 40-49mOhm
