RD6018 RD6018W 60V 18A power supply is published
there is a button to contact the seller, if you have any questions, you can send us message, and we will reply soon.
https://www.aliexpress.com/item/1005001488070904.html
some frequently asked questions recently:
www.youtube.com/embed/G7bcv9By4Og
RD6018W feedback
Fast shipping. Two weeks in Belarus. Quality packaging. High quality product. The seller answers all questions. Recommend. I will order more.
share a DIY PSU based on RD6018
RD6018W feedback
very fast, I tested and everything is ok
the next promotion should be 618 promotion, but it starts from June 21th, and ens at June 25th, if you have our products in your cart or wish list, you can check the price at that time
RD6018 review
A very good power supply, detailed product description, easy to use, like it!
https://aliexpress.com/item/1005001488070904.html
share a workbench with RD products
RD6018: https://www.aliexpress.com/item/1005001488070904.html
Compared with low current version, we found that most customers prefer higher current version RD6018 (18A), but they also want us to release 5 digit version, we will release RD6012P later, for other model, we need to judge the situation(materials)
RD6018W feedback
the inverter has great performance. in conjunction with a computer via USB for extended possibilities. the quality of the power supply is surprisingly good. in the future I will open up buying another one.
Hello Robbie,
The answers to this I received were vague and not really helpful.
I suspect he didn’t know.
I subsequently purchased a second RD6018 but this time a complete machine.
It came with an S-800-65v power supply inside.
I can confirm that the RD6018 will deliver 18A on 110v.
Regardless of other misinformation.
So far 14.4
Will have to rig up a 24v battery to test at 24v
I have a 48v battery arriving next week I can test at 50v
But I suspect the current will drop off as voltage increases.
My main use is for LiFePO4 12vbatteries so I’m good
If I can charge my 48v ebike battery with it even at lower current ….still good
Yeah. I just bought some cool 18650 battery holders off of ebay that can hold 4 cells and they have solder tabs so I can wire them in parallel or series and charge 4 of them at a time with the RD6018 any way I want. I could combine more and charge as many 18650’s at one time as I care to….up to the 18A limit.
The battery charge feature is nice and shuts it off automatically at the preset voltage.
I liked my first RD6018W so much I just had to have a second one.
It seems I find 1000 uses for a good power supply.
there are 2 PSU you can choose for RD6018, you can choose the one suitable for you
800W PSU can let RD6018 output 18A, but it cannot let RD6018 full output because it is lower than the max output power of RD6018(1080W)
1000W PSU is 68V 17A output at 220V AC input, it can let RD6018 full output, but it is 68V 14.7A (about 1000W) at110V AC input, so it cannot let RD6018 full output, pleaseset the power limit to 950W in RD6018 setting. It can be placed in S800 case.
Just in case you didn’t know the news, there will be summer sale after 9 days, from 21th(PST), the price of each products will be lower than normal.
RD6018W feedback
This power supply is good and cost-effective. Easy and fast to use. Some product details there is space for improvement, recommend!
Share a RD6018W feedback
RD6018W:https://www.aliexpress.com/item/1005001488070904.html
RD6018W feedback
The item is as described, it arrived in perfect condition and there were no issues with assembly. I would recommend this product to anyone in need of a powerful adjustable power supply
(but you need to use green terminal to charge battery)
hello, today I see a feedback, the customer remove the case to compare the PSU, it is ok, but when you use it, please install upper panel, because the fan in the PSU is used to deliver the heat inde the PSU, not the heat in whole S800 case
RD6018 feedback
Received within 1 month in Pakistan but not yet tested thanks
