Link is on the second banner.
Ah, I see. Thx.
Highlights of 50.2 vs. 50.3 differences:
- Much better thermal resistance (1.2 K/W vs 0.4 K/W)
- Vf is slightly more stable when temperature changes. Coupled with the thermal resistance improvement, this is really going to be quite stable.
- Same max current. Weird.
- There are higher bins available, in general we can expect to get 1-2 bins up
- XHP50.3 HI as about as efficient as XHP50.2 HD
- XHP50.3 HI is available down to 3000K and up to 90 CRI, but you can’t have them both. The lowest CCT with CR>70 is 4000K.
- XHP50.3 has slightly higher Vf (2.97 vs 2.9 at 6A).
In ANSI bins (pages 15-17) yes, but in Easywhite bins they are listed with 90CRI down to 2700K (pages 12-14)
Right! That’s a very good news.
XHP70.3 datasheet
https://www.cutter.com.au/product-category/led-emitter/cree-led/cree-xlamp/cree-xhp/cree-xhp70/
Comparing XHP70.3 with 70.2 I see:
- Much lower thermal resistance (0.2K/W vs 0.7 K/W). I also note that now they measure according to a JEDEC standard. XHP70.2 datasheet doesn’t mention that, so measurement methods might be different and so - the numbers might not be directly comparable
- Vf changes a little less with temperature and is marginally higher
- Again I see that these tend to have 1 bin up
- Light emission is slightly narrower, FWHM is 120° rather than 125°.
Thank you welight for these datasheets!
this is very useful data, thanks
Also from the XHP50.3 data sheet, “configurable to 3 V, 6 V or 12 V by PCB layout”
Finally, one emitter covers the entire voltage gamete. Why didn’t they do this from the beginning? Im looking forward to trying out the XHP50.3 HI in a few older flashlights that need upgrades.
With the 3V and 6V LEDs having the same pad layout, I don’t think that’ll be the case.
Anyhow, looks like we’ll have an updated 70.2 that’s a little throwier, and a 50.2 that’s much throwier. This will probably be a simple reflow to make the FT03 and other 50.2 lights a lot throwier without sacrificing too much output. Double the intensity as previous xhp50 iterations as they said.
Yeah page 41 there is the internal diagram, it’s still 2 string of 2 LEDs in series for the 6-12V version.
The 3v is a specific version, only the the standard version can be run as 6 or 12 on a dual board ie
cheers
wow sweet! really looking forward to this!
There’re all listed on Mouser but only high MOC and nothing on order.
Broken link? 403 forbidden
Weird, that link works for me.
I hope to see some of the new emitters soon that we can buy!
XHP50D-H0-0000-0D0UH245G expected dec/08/21
XHP50.3 HI flux H2, 90CRI, 4500K, 3-step
A surprise to be sure, but a welcome one.
“XHP50D-H0-0000-0D0UH245G”:https://www.mouser.fr/ProductDetail/Cree-LED/XHP50D-H0-0000-0D0UH245G?qs=ljCeji4nMDnxlRN1Ckk1mw%3D%3D expected dec/08/21 XHP50.3 HI flux H2, 90CRI, 4500K, 3-step A surprise to be sure, but a welcome one.
LOOOL
I just placed them in the cart when I went to BLF just to see your comment
… And I still haven’t managed to open my R50
LOOOL
Is that you whom already took 10 ?
Let’s hope they have a decent tint and low angular tint shift.
