I would appreciate a code for the SC31 Pro 5000k
Please send a code for SC31 Pro 5000K
there's no BS going on in this thread, I have worked with the OP, they are legit. They probably just got a pm restriction from the forum, it happens to me too on occasion.
Coul I please have code for sofirn SP35? 5000k 21700?
Thank you!
If possible, I would also like an AmazonUS discount code for the SP35 (5000K with 21700 battery).
Thanks Sofirn.
Hi, I just noticed your comment and I apologize for my late response. Here is the code for sc31 pro 5000k version: ZM3NHXPV Enjoy it!
The code has been sent to your message, please check it out, thanks!
Those loooong codes are one-time-use only, for anyone. If posted to you publicly here, anyone else could just as easily use that code, and you’d be SOL.
Thank you for your explanation! :innocent:
Hello,
Can I get code for SP35 and also SC31 Pro 5000K?
Thanks in advance.
Yes, please check your message to receive the codes. Thanks!
Hello,
Thanks in advance.
Can I please get code for SC31 Pro 5000K?
Yes, here you are, the code for 5000k version: ZM3NHXPV
Enjoy it!
Still available coupons for the 5000K variant?
Code for SC21 is available! 30%off discount! Here is the code: 2TC8-YL7KSM-LXJBA7
XTURNEL:Still available coupons for the 5000K variant?
Did you mean to type SC21? I tried it on the SC21 and it doesn’t work.
The code is only can be applied for once. If you’d like a code for SC21, I’ll send one to you message.
Sofirn:Code for SC21 is available! 30%off discount! Here is the code: 2TC8-YL7KSM-LXJBA7
jasontheguitarist: Sofirn:Code for SC21 is available! 30%off discount! Here is the code: 2TC8-YL7KSM-LXJBA7
Hello, would you send me a SC21 code, please?
Could I have a code for the SC21 and SC31 Pro 5000k?
Thanks!
Yes, I’ll PM you the codes.
Thanks!
