The GT mini is a very nice light. But if size and weight are no problem, I would get a Convoy L6 with the XHP70.2 led.
Just pass on the batteries and get some quality ones. You will need a charger too.
thanks, could not find any info about range/throw for the L6, do you know what it might be? or how the L6 throw compares to the L21A which is advertized at over 1000m?
I found somewhere mentioned that the usable throw range is about 30% of ANSI. so if I need about 600ft, I should be looking at about 600m, is that correct?
also, where do I find quality 26650 batteries? how do I know they are high quality?
This light gets very good performance like you stated. I do not have one, so I cannot compare it to my lights. In the video, it has a tiny beam size, and that is how it gets its throw, by intensity combined with small size equals distance. However its lack of light volume is disappointing. See the CPF review video below. https://www.aliexpress.com/item/1005001594138171.html
If you want to scare animals at night, get a bb gun, mount this Convoy light on it and shoot them in the behind.
Here is a review on the Convoy L6 XHP70.2 with an Smooth reflector which is a thrower. Matt’s web sight is down for repair, but he offeres the best L6 modded you can find. http://asflashlights.com/ XHP70.2 Convoy L6 4,300 Lumen
I prefer the XHP 70.2 because its very powerful, but does not throw as far by the numbers, but throws more volume of light at a decent distance. To get more light, you deal with HEAT. So these lights need a Husky Body to dissipate the heat. The L6 is Hefty.
I prefer throwers and most of my lights are. There is much advertising for distance in flashlights. The problem is, can you actually see anything with a light that states it can throw 2400 meters ? I have been there and was very disappointed in the actual performance. So I modded it to a XHP 70.2 and after the first mod it dropped to 1800 meters with 4x more light volume down stream.
Wildlife tuned to see in the dark unless they fly wilk usually just stand there as they can’t see a damn thing. What gets them moving as mentioned is noise, that triggers a response to move on as it replicates danger coming towards them. I’m constantly scari f off kangeroos off my lawn & noise or throwing an object near them scares them off.
I like the one on the right, with the narrower beam. however, since my harebrained idea might not work, I want to purchase from a place I can easily return, Amazon... and the only place I found the L21A was AliExpress, too long shipping time, and no easy returns...
purchased one, did not install it yet, the intention is to put it on angled arms (not sure if that's the correct terminology, but the arms on which you would normally put barbed wire on) on top of the fence
to complete the circuit, the critter will need to also touch the electric ground, so my plan is to make the entire existing fence "ground" and insulate the hot wire from the arms/fence.
we got this for safety, on the other hand, in over 20 years, never seen a coyote climb into our side, though skunks and opossums obviously made it... so far miss little monster was able to defeat these with only minor battle scars on her nose/cheeks
but this will not make her stop barking at critters outside the fence...
