Watches have to be the biggest joke every played on consumers. The most expensive watches are the least accurate. Its a knows fact, a $5 Timex is more accurate than a $20,000 Rolex.
Expensive watches are a symbol of wealth. There are YouTube videos of companies that rent them. So if you want to impress a lady, you can rent a $50K watch for $500/day.
Personally, I have a bias for mechanical watches since I admire the the required mechanical precision in the fabrication and workmanship that goes into them (at least the decent ones).
I guess its a bit analogous to the variety of cars perhaps… (pun intended)
Besides, still having the ability to tell time after an EMP shock provides some comfort…. even if it is –4 or +6 seconds off per day ….
My Casio Solar Atomic was been flawless for many years. The metal strap is held to the semi-metal case with some plastic links. These are the things that fail. As I expect they are designed to.
They are very nonstandard. I’ve cobbled them together a few times now. Going to fail for the last go round soon. Don’t remember what it cost, but it has been well worth it.
Never need to touch it, no battery, and the time is always correct.
A friends’ wife, many – many years ago. Was an oiler for Timex. Her station had some sort of magic dingus that dispensed a micro drop of lube when touched to the bearing.
They were expected to oil so XX many watches in a shift. Don’t remember what he told me.
There was bonus money for lubing beyond that number.
He told me his wife was one of the fastest lube(rs).
He also said that when a Timex came in for repair under the warranty, they would just chuck out the movement and put a new one in the case. Not worth anybodies time to fix it.
Here’s a question for y’all.
Do you take your watch off at night?
I often don’t. The Casio has a light up face that is bright enough to see with – with full dark adjusted eyes.
Who needs firefly mode on a flashlight when it’s built into your watch?
All the Best,
Jeff
PS.
Speaking of tail lights…
I once had a 73 Detomaso Pantera way back when. The tail lights were off a Maserati Bora. You did not want to brake one. The side running light were off a Mustang. Free with a happy meal at Autozone.
