If possible, I would also like an AmazonUS discount code for the SP35 (5000K with 21700 battery).
Thanks Sofirn.
Thanks Sofirn.
Hi, I just noticed your comment and I apologize for my late response. Here is the code for sc31 pro 5000k version: ZM3NHXPV Enjoy it!
The code has been sent to your message, please check it out, thanks!
Those loooong codes are one-time-use only, for anyone. If posted to you publicly here, anyone else could just as easily use that code, and you’d be SOL.
Thank you for your explanation! :innocent:
Hello,
Can I get code for SP35 and also SC31 Pro 5000K?
Thanks in advance.
Yes, please check your message to receive the codes. Thanks!
Hello,
Thanks in advance.
Can I please get code for SC31 Pro 5000K?
Yes, here you are, the code for 5000k version: ZM3NHXPV
Enjoy it!
Still available coupons for the 5000K variant?
Code for SC21 is available! 30%off discount! Here is the code: 2TC8-YL7KSM-LXJBA7
XTURNEL:Still available coupons for the 5000K variant?
Did you mean to type SC21? I tried it on the SC21 and it doesn’t work.
The code is only can be applied for once. If you’d like a code for SC21, I’ll send one to you message.
Sofirn:Code for SC21 is available! 30%off discount! Here is the code: 2TC8-YL7KSM-LXJBA7
jasontheguitarist: Sofirn:Code for SC21 is available! 30%off discount! Here is the code: 2TC8-YL7KSM-LXJBA7
Hello, would you send me a SC21 code, please?
Could I have a code for the SC21 and SC31 Pro 5000k?
Thanks!
Yes, I’ll PM you the codes.
Thanks!
I’m very interested in a headlamp Sofirn D25S. A code would be great if available. Thanks….
Is this offer still on? I’m interested in both Sofirn sc31 pro 5000k and your Sofirn sc31 pro 6500k . Will you supply me the codes?
What about a code for the D25L headlamp? D25L is almost looking like the D25S, but it features 5000k high 90 CRI LH351D led. Here is the code for D25L: 5KDT-B48AXJ-PXJJAY
Yes, here is the code for 5000K version:E4AQ2VMP Code for 6500K version: 152TBECY Would you like to try our new model SC21 keychain flashlight?
