About flashlights’ maintenance
16 posts / 0 new
xtarflashlight
xtarflashlight's picture
Last seen: 15 hours 13 min ago
Flashlights’ maintenance is essential to prolong the life of them. How do you care and maintain your flashlights? There are some suggestions, which may help keeping flashlights in good condition.
Cleaning and inspecting the flashlight body
First off, look over the body of the flashlight, especially around the bezel and lens. Check to see if there are any visible signs of any damage. Use a small nylon brush to loosen any dirt or mud that may have become stuck. And for lens’ dust and dirt, use a microfiber cloth dipped into some soapy water and carefully wipe over the lens.
Cleaning the threads
The threads should have a smooth action when unscrewing. If they feel gritty or unsmooth, there may be any dirt or dust has got onto the threads. After you have the flashlight disassembled with the battery removed. It’s time to clean the threads on the body. Remove the O-ring seal if it shows visible signs of damage. Rub some Isopropyl alcohol with using a soft cloth around the threads. The O-ring should be removed easily after you cleaned any dirt and grease. If the O-ring is stuck, use a ring and seal pick tool to loosen. Replace a new O-ring seal if it was damaged.
Lubricating the threads
After cleaning the threads on the body of your flashlight. Then to apply some lubricant to both the threads and O-ring. Use some lubricating oil around the threads sparingly using a cotton swab. And it’s important to use the correct type of oil and suitable lubricant. Generally, petroleum based jelly may deteriorate O-rings over time.
Check for oxidized or dirty contacts
Check both the tail and head of the flashlight for corrosion and dirt. Use a clean cloth to remove any grease or dirt from all the shiny metal contacts. Make sure the body of the flashlight is screwed back the correct way. And check if the switch works fine.
Keep up this simple maintenance activity for your flashlights 1 or 2 times a year, and it will help them stay in good condition. If you have other suggestions, can share freely.
Robin Dobbie
Last seen: 1 week 4 days ago
I just throw ‘em in the worshin’ machine. With a freshly-charged cell, I toss ‘em in the dryer on turbo and that takes care of any microbes. Then I do a reflash of the MCU for a fresh install of Anduril OS 12. Noticed my FWAAAA was getting a bit toasty for no reason, turned out it caught a crypto virus and was mining bitcoin in my pocket. Damn miners.
zoulas
zoulas's picture
Last seen: 1 min 11 sec ago
I have yet to need to change worn out o-rings on lights. By the time they need changing, the extras they give you will be dry rotted as well.
toddcshoe
toddcshoe's picture
Last seen: 19 hours 8 min ago
Funniest thing I have read in a while around here. Party on my friend. Big Smile
"Everywhere I go, there I am"
CR888
Last seen: 9 hours 28 min ago
The ones I put grease on threads attracted dust, sand dirt and grit. Flashlights need little maintenance IMO, just clean the contacts & use healthy cells.
CR888
GhostJoe
Last seen: 3 weeks 1 day ago
Looks like Xtar is going to release their flashlight/charger/battery maintenance kit……
wle
wle's picture
Last seen: 4 hours 17 min ago
nah to all of that
if they quit working, i go see why
none of this saves time, imho
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
zoulas
zoulas's picture
Flashlights don’t need maintenance. Does your stereo receiver need maintenance?
raccoon city
raccoon city's picture
Last seen: 8 hours 53 min ago
toddcshoe wrote:
Robin Dobbie wrote:
I just throw 'em in the worshin' machine. With a freshly-charged cell, I toss 'em in the dryer on turbo and that takes care of any microbes. Then I do a reflash of the MCU for a fresh install of Anduril OS 12. Noticed my FWAAAA was getting a bit toasty for no reason, turned out it caught a crypto virus and was mining bitcoin in my pocket. Damn miners.
Yep, good stuff!  :BEER:
Hank33
Hank33's picture
Last seen: 41 min 18 sec ago
You forgot to add Bacteria cleaning to your steps. We all know there's a lot of nasties going around now.
1) Take Isopropyl Alcohol and apply generously to a clean cloth.
2) Wipe generously on flashlight body and batteries completely
3) Wash hands
4) Give yourself a hug
ShyOne
ShyOne's picture
Last seen: 1 hour 35 min ago
Hank33 wrote:
You forgot to add Bacteria cleaning to your steps. We all know there’s a lot of nasties going around now.
3) Wash hands
Hilarious… ✅ Big Smile Big Smile Big Smile Big Smile Thumbs Up Glasses
Bort
Bort's picture
Last seen: 4 hours 32 min ago
I have to change the needle and dissemble and clean the contacts every now and then Big Smile
On some of my equipment i’ve even had to swap out a vacuum tube or two LOL
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
zoulas
zoulas's picture
True, the older stereo equipment needed replacement tubes and the older flashlights needed replacement bulbs.
Bort
Bort's picture
I will never upgrade, you young ones and your transistor radios Silly
I have cleaned the bare metal for good contact on some heavily used lights and re-lubed threads but thats about it.
I had a light stop running because the bare metal had too much gunk on it but a q-tip fixed that.
NeutralFan
NeutralFan's picture
Last seen: 1 day 22 hours ago
Flashlight maintenance for me is:
  • Remove the old dark lube off the threads with a rag (ex. inside of an old sock)
  • Take a toothpick and add new lube (ex. Super Lube ) to the threads and O-rings. I found using a cotton swab leaves cotton threads behind.
  • Clean the contact points on the springs and battery with a cotton swab and isopropyl alcohol
I’d rather use my flashlight around the house than turn on the lights.
Jack Kellar
Jack Kellar's picture
Last seen: 2 hours 28 min ago
Lucky. I’ve had to swap out the o-rings on a few of my twisties. I kept the replacements inside the original ziploc baggies and they were just like new.
