Test/review of Vapcell INR21700 5000mAh T50 (Red) 2020
36 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 43 min ago
DSC_4203
Official specifications:
  • Size: 21.1*70.5mm
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50V
  • Typical Capacity: 5000mAh (0.2C discharge)
  • Min capacity: 4900mAh (0.2C discharge)
  • Weight: Max:72g
  • Internal resistance: Max:12mOhm (AC 1kHz)
  • Standard Charge: 2000mA,CCCV 100mA cut-off
  • Quick Charge Current: 5000mA
  • Max Continuous Discharge Current: 20000mA (20A)
  • Max Discharge Current: 35000mA (35A) With 80°C temperature cut
  • Operating Temperature: Charging, 0°C ~ 45°C
  • Operating Temperature: Discharging, -20°C ~ 70°C
  • Storage Temperature: -5°C ~ 35°C
Vapcell%20INR21700%205000mAh%20T50%20(Red)%202020-info
This is a 21700 LiIon cells from Vapcell. The cell is high capacity and also fairly high current.
DSC_4201 DSC_4202
DSC_4204 DSC_4205
DSC_4206
DSC_4207
DSC_4208
Vapcell%20INR21700%205000mAh%20T50%20(Red)%202020-Capacity
The two cells tracks nicely, the cell gets hot at high current.
Vapcell%20INR21700%205000mAh%20T50%20(Red)%202020-Temp-15.0
Vapcell%20INR21700%205000mAh%20T50%20(Red)%202020-Temp-20.0
Vapcell%20INR21700%205000mAh%20T50%20(Red)%202020-Temp-30.0
Vapcell%20INR21700%205000mAh%20T50%20(Red)%202020-CapacityTimeHours
Vapcell%20INR21700%205000mAh%20T50%20(Red)%202020-Energy
Vapcell%20INR21700%205000mAh%20T50%20(Red)%202020-PowerLoadTime
Vapcell%20INR21700%205000mAh%20T50%20(Red)%202020-TripCurrent
Vapcell%20INR21700%205000mAh%20T50%20(Red)%202020-Charge
Discharge-Vapcell%20INR21700%205000mAh%20T50%20%28Red%29%202020-pulse-1.0%2010%2010-IR
Conclusion
The cells looks like good high capacity 21700.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
thefreeman
thefreeman's picture
Last seen: 29 min 22 sec ago
Thank you for the test. This 50S/T50 looks excellent.
MascaratumB
MascaratumB's picture
Last seen: 10 hours 48 min ago
Thanks for the test HKJ!
Bought some of these in Vapcell store, seems like it was a good bet Thumbs Up
Th558
Th558's picture
Last seen: 13 hours 45 min ago
Thanks. Been waiting for this! Using this battery chemistry, I’m pretty sure they could make a 3500mah 18650 with close to 30Q performance..or a 40S with 30T performance.
Caleb
Caleb's picture
Last seen: 3 days 7 hours ago
HKJ, thanks for all your hard work!
Superstocker
Superstocker's picture
Last seen: 5 hours 39 min ago
Thanks HKJ! These look really good.
JamesB
Last seen: 2 weeks 4 days ago
A strong performer, i’m wondering if some kind of compromise to cycle life had to be made.
LTC
Last seen: 15 hours 57 min ago
Thumbs up again…
id30209
id30209's picture
Last seen: 20 min 6 sec ago
these cells aren't available anywhere. Great specs but just unreachable
WTB Titanium 4sevens 2xAA tube
cabshank
Last seen: 2 weeks 1 day ago
id30209 wrote:
these cells aren’t available anywhere. Great specs but just unreachable
yeah, does anyone have a lead on when they will be available?
vapcell Dennis
vapcell Dennis's picture
Last seen: 23 hours 43 min ago
Thank you, HKJ Thumbs Up
Sillen
Sillen's picture
Last seen: 2 days 2 hours ago
now we just need some stock Big Smile
JaredM
JaredM's picture
Last seen: 1 day 4 hours ago
+100
Barkuti
Barkuti's picture
Last seen: 2 days 7 hours ago
So this is a rewrapped Samsung INR21700-50S, doesn't it?
20A continuous? Seriously? According to HKJ's graph, the cell overheats a bit before full discharge with cut-off at +50°C (this is equal to 75°C with 25°C ambient temperature). Typical maximum allowed cell temperature is 80°C, so… a bit tight, imho.
I see there's been an overall improvement in discharge performance, this is great as it means less heat or energy lost in the batteries as the current flows. However, how about energy density? They better get on it now that there's barely any oil to extract… Innocent
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
Pavlo
Last seen: 5 hours 10 min ago
Anybody know where to buy one of these cells? They seem to be the best battery that compromises between capacity and high discharge rate.
Sunnysunsun
Sunnysunsun's picture
Last seen: 6 hours 24 min ago
Nope, nowhere reliable.
Pavlo
Damn.. any good alternatives worth considering?
Sunnysunsun
If you need capacity, 50G, Molicel M50 or even sofirn’s 5000mA 21700s if you want cheap prices and decent performance seeing as how there’s a shortage of Samsung cells. 40T, Molicel P42A for higher drain. 30T for absolute max output with multi 50.2 fet lights
Pavlo
18650Canada has the 40T’s, but this T50 outperforms the 40T up to 15amps, which would suit majority of my lights…
Sunnysunsun
Well I don’t see it being available in the next 3 months, maybe we’ll get lucky in 6 months or near the end of the year. There’s a major battery shortage going on right now. Check the typical American battery sellers. No stock of a lot of Samsung, LG, Sony cells.
Pavlo
Lets see if I can wait that long. Thanks for your input!
Sillen
Sillen's picture
Pavlo
I noticed… Have they always been that expensive? Seems like a big premium to pay for the boost in performance over competitor batteries.
Sillen
Sillen's picture
Yup. Nov 2020 2 pieces, AU$ 35.22.
Today, 4 pieces, AU$ 93.34 though I have asked for a BLF discount.
Barkuti
Barkuti's picture
Sillen wrote:
back in stock https://www.aliexpress.com/item/1005001587009631.html
Pavlo wrote:
I noticed... Have they always been that expensive? Seems like a big premium to pay for the boost in performance over competitor batteries.
Do you know how much Vapcell does really pay for these cells? Also, do you know of any other place to buy them?
Particularly in these matters their strategy is to hoard and hog the product, and then place over it the price sticker they like. Of course it's not exactly like this, but they do feed out of your addictions. Are you addicted to having to buy the latest whatever, just because it @#$% extra performance which in practice you may not even notice without a measurement device or at all? Do you really need such a thing?
It's been years since I don't see any higher energy density technology. Comparing, for example, the Samsung 35E versus the muuuch newer 50G, there's absolutely no energy density versus mass improvement. What are they waiting for? Are they waiting for… Christmas? Big Smile
Long ago I heard in the grapevine that the oil wells were drying. And of course, they're dry. There were huge amounts of oil reserves, this is the reason things work. The Covid-19 farce is in part concealing this fact. But the clock is ticking. Do you think the cars of the future are going to be powered with this energy density lackluster battery technology? I know they can, they're selling you the extraordinary performance of electric motors to sell the new electric cars. But if we are to speak about their mileage or range, this cannot hide the obvious fact: it sucks. But well, this is another story…
Tom E
Tom E's picture
Last seen: 20 hours 50 min ago
This is a big increase. I paid $24/pair + tax back in November ($22/pair in October), now the same pair is $36 + tax, so 50% bump.
I'm out at this price. There's not even much of a discount with qty up to 10. They have to do better than this.
yasenf
Last seen: 20 hours 21 min ago
If it is Samsung cell inside, it will not go lower soon – nkon almost doubled Samsung prices in EU since end 2020…I guess Samsung and the other major brands benefit the boom of the EV.
Tom E
Tom E's picture
Ahh, ok. Yes - nearly sure it's a Samsung 50S. Let's see what Dennis has to say, I hope??
These Samsungs here at 18650BatteryStore are still reasonable, accept hhhmmm, no stock frown
vapcell Dennis
I’m out at this price. There’s not even much of a discount with qty up to 10. They have to do better than this.
Recently, the price of batteries has gone up too fast. The unit price of Samsung batteries is almost twice that of the previous ones
The cost price of T50 is also very high. We have no choice but to look forward to more quantity and lower price in the future
vapcell Dennis
Yeah,LG Samsung murata ,sanyo Crying
Tom E
Tom E's picture
K, will wait a while and see. Thanks!
