I have the same UI as Funtastic. It’s not really a bother but it does have memory mode so it would be nice to go down when in the medium modes rather than cycle through high. I also can’t seem to go down in modes immediately after turning it on. Just seems like a weird behavior. Though at it’s price I can’t really complain much. I knew I should have gotten more than one Quadrupel driver :person_facepalming:
Oh ok I think I get it now. Thanks. Though mine is just within a second. The timing seems to leave little room for error on mine. I guess I’ll just use L-H cycle to avoid frustrations.
with 2 Anduril Drivers from Quadrupel and one Attiny 412 from gchart. The second Attiny got a broken leg after some problems with a short causing the LED was always on.
But finaly all 3 Headlamps has ramping with Ramping iOS or Anduril.
I had two Drivers with Ver03 and one with Ver01, so the Ver03 got the Attiny 412.
Thanks to you both.
I changed the LEDs too:
2x LH351d 2700K + 5000K 90CRI
2x XM-L2 NW (3B or similar)
1x SST40 5000K
Drivers and Flashlights from recent posts for reference:
Are there any TIR optics that are simple drop-ins for either the D25/D10? Browsed quickly through this thread and it looks like the ones that people recommend still need some shaving down to fit.
Depends, they probably changed the process over time. Most people were successful with opening D25-family lights, but some reported that they couldn’t open theirs.
D25 have user friendly design.
I have early version of D25 from start of production, where MCPCB with LEDs is pressed to the hole in body headlamp and there is no mass under it.
Second version of D25 from 12/2020- BORUIT have flat surface under MCPCB with good thermal path.
I was curious, what type of design have this headlamp and if it is possible to swap LEDs and make some “Nichia flooder” from it.
Tried to open a D25LR, same host. But geez it’s impossible, even almost broke my tool. Turned CCW and it maybe moved a little judging by the few creaking noises, but nothing else. Completely stuck :person_facepalming:
