Sofirn SC21 mini
261 posts / 0 new
TheAuditor
Last seen: 2 hours 25 min ago
Sofirn SC21 mini
Bonum commune communitatis.
Yarp.
nobody
Last seen: 1 month 4 days ago
That does look interesting.  Clicks off a lot of boxes.  Would like to see some beam shots though.
Lightbringer
Lightbringer's picture
Last seen: 3 hours 7 min ago
Noice! And it’s only egg-weight, too!
I’d love to see it in a TIR vs reflector, though. Wonder if a 17mm/20mm would fit.
Hank33
Hank33's picture
Last seen: 7 months 1 week ago
Cool! Finally, I can make good use of my Shockli 16340. Will order one. Smile
zoulas
zoulas's picture
Last seen: 1 hour 40 min ago
Is this any good or is it an afterthought?
carmantl
Last seen: 1 day 22 min ago
Looks good but I think the 16340 is SO limited compared to an 18350.
CR888
Last seen: 7 months 22 hours ago
Kinda not much different than a SP31-pro with short 18350 battery & tube except less lumens & runtime. Nice light though.
CR888
Sirstinky
Last seen: 4 hours 54 min ago
1000 lumens in that will last a couple seconds, but with ramping looks good especially using the LH351D. $25 is pretty steep for that though when the FWAA is only $20 more…
toddcshoe
toddcshoe's picture
Last seen: 2 days 4 hours ago
Yeah but the FWAA still has FW problems. There are decent 16340 cells out here now days. No reason not to buy this light if it fits the form factor you are looking for. I have a boat load of Vapcell 16340’s, now Sofrin has givin me something to use them on.
"Everywhere I go, there I am"
mortuus
mortuus's picture
Last seen: 2 hours 10 min ago
it should manage atleast 30 sec or so… similar olights manage that so this one should too.
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
derfyled
derfyled's picture
Last seen: 3 days 17 hours ago
Is there a deal on it right now ?
The Sofirn site does not want to show me shipping fees for Canada.
First CR123 sized light I’m interested in a long time…
carmantl
SC31PRO WITH 18350 TUBE COSTS LESS.
Unheard
Unheard's picture
Last seen: 1 hour 45 min ago
Your shift key is stuck.
Smile, you cannot kill them all.
Lightbringer
Either that or he’s Samu L Jackson. Evil
derfyled
derfyled's picture
Yes but it’s not as small. I would really like to see a comparison picture with both lights.
Lux-Perpetua
Lux-Perpetua's picture
derfyled wrote:
Yes but it's not as small. I would really like to see a comparison picture with both lights.
I have the prototype here. The light was originally planned to be sold under a different brand.
From left to right: Sofirn SC21 prototype, Wurkkos FC11 w/ 18350 tube, Sofirn SC31 Pro w/ 18650 tube
I have recommended Sofirn to enlarge the inner tube diameter to fit 18350 batteries. It seems they decided otherwise. The input current of 1A via USB-C (equals to about 1.5C) is a bit much for this small battery and may reduce its life span.
CR888
I bought 3 SP31’s with extra short tubes, magnetic tailcaps & diffusers. Very good little lights for the money. I grab the short 18350 over my Olight baton-III as it’s more powerful and sustains higher outputs for much longer. The little 16340 Olight on turbo chews most of its power in under a minute. I like the Olight as it has that Zippo style unique charging case and it’s a good light but if going out for a walk for an hour it’s just not the right choice. I’ll probably buy this new Sofirn just based on their value for MSRP but I bet the short tube SP-31p does everything brighter longer for a small increase in size. Olight 16340=550mAh vs Vapecel T14 18350=1400mAh….so yeah a fair bit of difference for such similar sized cells.
CR888
skinny_tie
skinny_tie's picture
Last seen: 23 hours 57 min ago
This looks good. I’d like to get one but I’ll wait for more information about the UI. So far I haven’t seen a good ramping UI besides Narsil and Anduril. My only experience with a Sofirn ramping UI is the C8F which I hate.
Unheard
Unheard's picture
The C8F UI has (had?) a severe bug (will stuck in moon mode). With that one corrected, it’s a nice UI (SP33V3 seems ok). The only thing I would add is the ability to ramp up- and downward randomly, like Crescendo does and unlike Andúril which annoyingly forces you to wait until you can ramp up after already ramping up. Annoying.
Any kind of regulation in this light? Is there a runtime diagram already?
Lightbringer
I’m gonna hafta play with my C8F, as I don’t recall anything evil in the UI.
Only thing I had issue with was turning it really off I’d turn it off via the sideswitch, then unclick the tailswitch, then TCLO the beastie. (Yeah, overkill.) Gotta remember to do all 3 in reverse to just turn it on again. LOL
derfyled
derfyled's picture
Lux-Perpetua,
Thank you so much for posting this, I appreciate. That.s exactely what I needed to see. Thumbs Up
S33k3r
Since I'm a total noob... Would you mind breaking this down a little further for me, please? I've inherited -- long story -- a Torchy and an OlightS1R, and would like something similar. I don't mind going a little larger to get a longer run time. Thanks for any help!
jon_slider
jon_slider's picture
Last seen: 10 hours 4 min ago
very helpful photo
the advantage of 16340 is that it is lower weight and smaller size
16340, 18350, 18650:
here is the 18350 version:
(pic is a link)
the advantage of 18350 is that it has more capacity
the disadvantage is the battery, and the light it fits into, is larger, and heavier..
S33k3r wrote:
Would you mind breaking this down a little further for me, please? I’ve inherited… an OlightS1R
your S1R uses a 550mAh Battery, size 16340 (16mm diameter, 34.0mm long),
that weighs about 18 grams
an 18350 Battery (18mm diameter, 35.0mm long),
that weighs about 25 grams,
is available in 1200mAh capacity,
double the capacity of the Olight battery.
however, if we use less lumens, we get more runtime
it can be misleading to focus on maximum lumen runtimes, if in reality we seldom use maximum..
so, be happy with your 16340 light and dont worry about capacity and runtime, instead, avoid using maximum.. Smile
16340 is 2mm smaller in diameter than 18350
Example Sofirn SC21
a light whose head was designed for a 16340 body tube, will not accept an 18350 body tube, because the diameter is 2mm larger.. the parts wont screw together.
Example Sofirn SC31
an 18650 flashlight can easily use an 18350 body tube, because they are the same diameter.
16340 in 18350 body tube:
18350 in 18350 body tube:
S33k3r
Thanks! I went to the Sofirm site and found the IF25A, so am looking into it now, too!
S33k3r
Don't laugh, but there is a point to what I am seeking. I am blessed to have a large backyard. Large enough that I have to sometimes search for my dogs at night, after letting them out. I'm looking for 1k lumens or so, such that I can light up 1/2 to 3/4 of my yard enough to see where they are/what they are doing. But because I am sometimes wrangling them, a small light I can clip to my collar is most desireable (once I find them, LOL).
Thank you for the explanation!
jon_slider
S33k3r wrote:
a small light
one man’s small is another man’s large…
I suggest you develop some data regarding the weight of each light you consider, as a basis for comparison.
OlightS1R compare and contrast to Sofirn SC21
Olight LED is not HIGH CRI
to me, High CRI is a required feature, and is the reason I no longer own any Olights.
Sofirn offers High CRI, Olight does not
Olight UI is not Anduril
I like the Olight UI, but not their LEDs
Anduril UI is MUCH more complicated, and requires a LOT more clicking to access all the extra features..
Anduril is a very high output capable UI. People have been hurt when the light accidentally turns on in their pocket. Prudence dictates locking out lights that run Anduril. Locking out requires 4 clicks to lock, and 4 clicks to unlock.
to me that is a ridiculous amount of clicking, and one of the main reasons I do not own any Anduril lights myself
otoh, if Anduril UI interests you, the SC21 is the smallest and lightest Anduril light presently available
to be fair, Anduril is extremely versatile and capable, and can be set up to be as simple or as complex as you like..
warning, if you slide down the Anduril Slope, you will soon be buying an Emissar D4V2 with aux lights… and more.. you have been warned Smile
welcome to our support group.. LOL
S33k3r
Based on your response, I went over to the general area and spelled out "small". Thank you for your help!
Will
Tendou
Last seen: 21 hours 30 min ago
I think the SC21 is not anduril.
jon_slider
I dont own the light, and you might be right…
I just read a link here
the word Anduril does not appear.. so, who knows?
it does say:
Group 1: Stepped mode group
Group 2: Ramping group
Lux-Perpetua
SC21 does not use Andúril but more or less a quite similar UI as SP35. An excerpt from the manual...
jon_slider
thank you
similar 4 click lock and unlock as Anduril
similar stepped and ramping modes as Anduril
I dont know all the differences between Narsil, Bistro, Anduril etc
imo ramping is a useful UI
as is the option to use stepped modes instead
so afaict, this is the smallerst light available today, with a ramping UI…
Is there an AA/Eneloop version of a light with a ramping UI?
(that does not require LiIon?)
