That oversaturated skin tone is why I have a love/hate relationship with 219b… 103 rg
Sunlike much nicer, good sst20 bins too
the LH351d is a popular alternative
it does not have the sw45k signature hyper pink feature/bug
glad you dont find them too green…
Someone should do a poll/survey comparing colorblind vs not people and whether 70 vs 90 CRI is perceptibly very different.
For me, it’s such a huge difference. Even before owning any neutral white LED flashlights - let alone 90+ CRI! - I hated the color quality. Reminds me of the worst florescent lighting I’ve seen, and really felt like it “blended” the colors of things together, making it harder to distinguish different things of even fairly different color.
The only comparable I have seen is high voltage Thrive/ Optisolis/Sunlike, and sst20 FA4 which is lower CCT and still +duv therefore not in the same class, nevermind the aforemention high voltage issues
Lh351d has too awful r9 to be in same class. I would argue e21a is better, but is still oversaturated a little
and still +duv
That’s kind of the point though? It’s the very low duv of the “k” binned 219Bs that causes that skewed color rendition/perception. You can always fine-tune that with -green filters w/other emitters anyway (and still be close to 219B in lm/W). Optisolis definitely doesn’t have a duv anywhere near as low, because it’s meant to most closely match a blackbody radiator.
SST-20 and LH351D are nice because you can slap them into just about any light, with any (3V) driver and just let it rip. E21A needs proper board and has tint shift without frosted optics (and donut-hole in quadtrix setup w/o frosted) and 219B still requires limited drive current.
It’s the same like listening to high(er) fidelity audio. Still as a n00b and with a relatively “tin ear”, you might not notice any difference at first, but once you acclimate to it, going back to lo-fi sounds like crap.
Ymmv.
Although I do see your point, it’s a known fact that it’s virtually impossible to tell the difference between a $5000 sound system and a $50,000 sound system. The people that spend $50K like knowing their specs are hard to beat but the human ear really cannot tell the difference.
I laugh when I read reviews of a turntable that floats on a cushion of air, has a 50lb platter, and cost as much as a house. Then the person that buys it claims Dark side of the moon sounds incredible on it.
… … …claims Dark side of the moon sounds incredible on it.
Dark Side of the Moon sounds best when it is playing in my head. But it is not me playing it in my head, it is someone in my head but it’s not me.
CRI? As long as the ting is not grey, I am happy.
Makes sense that my eyes aren’t trained to see it. On the flip side, I’m a trained musician and HQ audio does make a difference for me. Maybe not in a specifically describable way, but CD-quality and above just feels smoother on my ears.
I still like the light quite a lot and it has more value to me than just CRI.
I found this helpful.
I have generally found that emitter characteristics work like a dart board. Here’s how the concepts map: Color temperature is which concentric ring the dart lands in. The center is neutral white, and the outer rings are increasingly warm or cool. Tint is the angle of rotation, like whether it hits at 2-o’clock or 7 o’clock. Some tints look better than others. CRI is how close the dart is to the center of the cell it landed in. It certainly helps, but not generally as much as the other factors. …
- Color temperature is which concentric ring the dart lands in. The center is neutral white, and the outer rings are increasingly warm or cool.
- Tint is the angle of rotation, like whether it hits at 2-o’clock or 7 o’clock. Some tints look better than others.
- CRI is how close the dart is to the center of the cell it landed in. It certainly helps, but not generally as much as the other factors.
I found this extremely interesting.
FWIW, here are beam shots of a few different lights ranging from 65 CRI to 92 CRI, including one which is wide-spectrum. No post-processing has been applied, except for the camera’s auto-white-balance mode to minimize color temperature differences and simulate how they look in person. Without looking at the file names, can you sort them in order of lowest to highest CRI? A: [image] B: [image] C: [image] D: [image] E: [image] F: [image] G: [image] … and here’s one which theoretically has…
A:
B:
C:
D:
E:
F:
G:… and here’s one which theoretically has 100 CRI since it’s an incandescent light. However, its 2700K tint makes everything look yellow. Here’s how it looks in person for me:
H:
Answers… Don’t cheat.
Before I forget… In the pics above, the CRI is (approximately): F: 65 (cheap SK-68 ~7000K) G: 70 (XM-L2 3C thrower hotspot) C: 70 (XM-L 1A floody) A: 75 (XP-G2 3B floody) E: 91 (219b, reflector) D: 93 (219b, reflector + diffuser) B: N/A (wide-spectrum, looks like >100 CRI) I don’t have very precise stats on these, so the numbers are pretty rough. In person it’s easier to guess the CRI, but after a trip through a camera and a screen, most of the extra color information has been discarded so …
We all noticed the difference when the CD was invented I believe. Friends of the turn-table argued that its specific sound was more pleasant, not necessarily more natural. Not sure if we all heard by how much the sound was degraded when mp3 players came out. I did immediately, and I still find mp3 terrible.
You had a difficult start into HCRI with the Samsung LH351D. I don’t like their tints down to maybe 2700K, where it is more yellowish than greenish. But I guarantee you’ll be able to identify a 219B sw45k light. I see it the other way round as has been described here: It is an eye opener after you were exposed to Cree lighting. It’s like switching from TV tube to HD LCD panel.
We can kinda guess the results of the poll but I’d be half interested in seeing it. I only have very mild colour blindness (a little of green and yellow) but it probably explains my low interest in high cri. Sure I see a difference when comparing low and high cri but I’m more of a practical type where any light is better than no light.
I often shop by “high CRI”. Even if it is missing some of the red spectrum or it isn’t perfect, I’m more likely to find lights that look nice to my eyes in that category. That said, a light done well is good thing.
Now that we are getting into summer, I’ve been able to find some nice wooded spots with pretty leaves, different bark tones, little flowers or fruits, etc. Switching back and forth between SST-20 at 2700K, LH351D at 3500K, Nichia 219C at 4000K, and XHP50.2 at both 3000K and 4000K; they all look decent. I don’t know that one blows the others away. They all look a little different, with the biggest differences being at the extremes of that spread. Of course, the differences are also more noticeable when switching back and forth or shining side by side.
Going for regular nature walks at night, I tend to enjoy just grabbing whatever I feel like taking. It adds to the experience. There are only a few quirks I’ve noticed. Really warm lights seem to look best when the world is green. As the world gets more brown and tan, I don’t like how things look with the 3000K and 2700K lights mentioned above. I’ve also found that 4000K looks great in concert with strong moonlight. I often reach for my Nichia 219C lights when the moon is shining.
sometimes the CRI is inflated
you may have been expecting warm white, which is more yellow than actual balanced CRI
i personally don;t care about going warmer or higher CRI than ‘neutral white’
because
a. color at night, what does it matter? and
b. anything that is less blue, is also less efficient
I would get high CRI lights, but high CRI emitters make compromises that I don't like.
Sometimes they're not as bright at lower CRI emitters, and the bigger problem is that they don't handle heat as well as some lower CRI emitters.
because
“Warm white” and “neutral white” refer to color temperature, not CRI. CRI is separate.
Most high-CRI leds used in flashlights tend to be 4000K or warmer. However, it is also possible to have cool white that is high CRI.
I see a clear difference in high CRI LH351D 4000K and the SST20 4000K vs. cool white Cree XP-G and XM-Ls. There is a difference not just in colour rendition but in depth perception on a subtle level (such as a PC aluminium fan grating, if it is partially full of dust I see the difference in where what I see is, i.e. behind it and at the front (dust level), whereas with the cool white LEDs it looks to be all at the front, flat like a photo. This was quite interesting. I had tested long ago with cool vs. neutral white LEDs outdoor in relation to use on bicycles, but now, for inside the house I found high CRI to be better in this respect here too, and something else: low CRI LEDs give me a feeling that something is off (missing in colours).
For me inside the house high CRI is more important than outside…
I tested with various LEDs, e.g. with a yellow spirit level (Stanley Fatmax): 1. 6000K, 2. ca. 4000K neutral white (XP-G 5B1), 3. 4000K neutral white 90 CRI LH-351D, 4. 4000K neutral white SST 20 95 CRI. The result is that between each of them there is a clearly visible difference of increase of vibrance of the yellow. It looks most washed out with 6000K and most vibrant with the SST20 4000K.
The SST20 lights up everything in a manner that is pleasant, I don’t care much for the LH351D though it’s better in some ways than the low CRI neutral white LEDs but it has a weird yellowish tint shining on white, whereas with the SST20 I don’t get that impression at all.
…There is a difference not just in colour rendition but in depth perception
excellent points, I agree
the SST has higher CRI R9 (Red) than the LH351D
both have tint above the BBL
they produce more lumens than 219b,
SST matches the CRI Ra and CRI R9 of 219b
Only the 219b has Tint below the BBL, more pink than SST and LH351
any of them has better red output, aka CRI R9, than xml or xp cree…
CRI R9 Red is separate from the Pink Tint of the sw45k, which has both, pink tint and 90+ CRI R9 Red spectrum content.
examples of different amounts of Red output, aka CRI R9:
sw45k, my benchmark, just focus on the Red bar:
Nice graph Jon Slider.
CRI with high R9 looks especially nice.
But that said, none of my in-use flashlights use SW45k 219B.
I have some of those LEDs laying around, but I find the output to be just too dim. I need more lumens.
CRI is important to me … but only to a point.
R9 of the LH351D 4000K is closer to 75 at medium currents. The 5000K washes out reds a bit by comparison.
