this is my second post here, I have narrowed down my first flashlight purchase selection to these two. mid range flooder all rounder is what I’m after and after few days search its a toss up between these two.
my requirements were:
USB rechargeable
good size (not too big) possible to pocket in a hoodie/jumper
good quality and built
good battery life
good spread and throw
good price under 80 usd ‘with batteries’
somewhat waterproof
can take a fall or two without being decommissioned
so these two lights have come up against the many other models. now im only comparing them in heat performance. i already know how good the m3c performs. the m3c can hold the same light intensity on high level with 1600lms until the battery runs out and the outer temperature would be in the 45C 113F range very acceptable.
But for the SP36 I could not find this information at all and i searched a lot. so my questions are about the thermal side of this model. I know it has multiple gradual light intensity modes, for simplicity lets group them low, med, high, turbo.
so I only would usually use my lights in high mode (one before turbo) so my question is would the sp36 Blf anduril starting from a full charge on high setting (not turbo);
1. would it gradually drop its brightness as its being used on this high setting? or would it not? or would it zigzag?
2. is it possible to set temperature limit in UI to a point where it would maintain the same light intensity ‘high’ until the battery runs out without light going up and down in intensity. (same as the convoy m3c)
3. is the sp36 comfortable to hold without burning your hands while being used until the battery runs out on ‘high’ mode? roughly after how many minutes would you say the heat gets uncomfortable in high mode after turning it on?
any help is greatly appreciated specially from people who used or own one or both of these flashlights.
