SFT70 LED will not be available until next year
Any chance of warmer color temperature like 5000k or 4500k SFT40 being available for sale?
I have put forward this suggestion to the manufacturer, but I think it is difficult to implement.
Is the SFT40 LED going to be available for the Z1 and other flashlights?
Thought that was only with the SST40 Gen 1?
I don’t know, maybe later versions are tougher. Even when they did fail by burned bond wires it was at >8.5A, so it was usually not a problem, but it will still be nice not to worry about that failure mechanism.
Does the SFT40 fit standard XML mounting stars (MCPCB)?
I just ordered mine and don't have any on hand, so I can't say for 100% positive. However, the pdf datasheet shows the die size as a 5050 which is the same as Cree XML.
Sirstinky: Simon Mao: flightless22:Simon, can you re-upload STF-70 datasheet and SFT-40 datasheet if you have it.
Hi Simon, thanks for the datasheets. Can you sell us sft-70 leds also?
Thanks Simon. Will be looking forward to that one!
The SST40 does, so this should as well.
yes,
yes
26800 extension tube for M3-C sample
Thank you Simon. When might we see them for sale?
Ordered 5 sft40 leds today, oh do I have plans for this LED!
Simon Mao:26800 extension tube for M3-C sample
i’m ready to produce silver / red / blue / gold version ,
i’m finding 26800 7000mAh battery with good quality
Could you please list some of the 26800 batteries and sources you’ve discovered. Also please consider Black as one of the colors.
Black lights matter?
Simon Mao:i’m ready to produce silver / red / blue / gold version ,
i’m finding 26800 7000mAh battery with good qualityCould you please list some of the 26800 batteries and sources you’ve discovered. Also please consider Black as one of the colors.
The black version may not look good.
here is 26800 battery what i got
L7 will be ready for SBT90.2 LED
That looks awesome. Might be my first SBT90 light.
Ramping driver?
Wow, that looks incredible, and knowing Convoy’s build quality it’ll be decent.
Ramping driver?
I find ramping only useful on models for EDC, not throwers. Quite a few were not a fan of the Noctigon K1 using Anduril
