I don’t know, I have 2 knives in 8Cr13MoV and I actually like both of them, someone who knows the steel makes a good knife out of every kind that can be hardened enough. Mine carry the names of Spyderco and Sanremnu and the makers behind these 2 brands obviously know this steel and made the best out of it. It does dull out some faster than say D2 or 14C28N but give them 6 or 8 swipes over any sharpener and they shave again. (yes, I also have knives in these 2 steels).
There is an important difference between being good relative to a person’s use and good relative to rest of the market.
For instance, consider 3Cr13. It’s a bottom-tier steel from the same series. Many companies use it to make their liners but we also see it used as blade steel. Edge retention is terrible relative to something like 8Cr13Mov. If a person only uses their knife as a letter opener, not for cutting cardboard but for actual paper envelopes, it is probably okay.
My issue is that if better steels have been widely available within the same price range, and especially if that’s been the case for years, then kudos to the companies offering better steel and thumbs down to the companies that don’t.
I got a cut like that once. I was tending bar at a pool party sometime last century. The martini glasses were made of actual glass back then. I was barefoot because it was a pool event. Somebody bumped into me while I was carrying a tray. One of the glasses shattered on my toe knuckle. It looked okay until I flexed my toe. Then I could cleanly see the bone for what probably seemed like longer then it actually was. Then the blood started.
There is a current thread discussing AO accidents on Blade Forums. Besides sharing the story of my own Leek pocket bite, I referenced this thread and mentioned what happened to you.
I've been collecting assisted-openers since 2008.
I have owned scores of them, and they're what I EDC over 99% of the time (when I have a knife on me.)
I've only drawn blood twice, and each injury was extremely minor.
Neither time was caused by the knife opening or closing.
I just accidentally knicked myself once and poked myself the other time.
I consider myself very lucky.
EDIT:
Actually, I drew blood one other time, but not by the razor sharp blade.
My most recent purchase was a dud.
It was surprisingly difficult to open the knife by pushing on the flipper, and where I was pressing was jagged, so I chewed up my finger and bled a little bit.
I returned that knife today via USPS.
Bought this Roper for $11.00 out of curiosity. Really a nice knife .
Ow. That had to suck.
Not many of my blades tasted blood. Think this one, maybe my go,comma/PF (just scratches; don’t recall actually drawing blood, though), and my old Sanremu.
Worst or at least most annoying cut was from an Xacto blade. Was opening a coconut(!) and it slipped and went like halfway in the fleshy part between thumb and forefinger.
Wouldn’t stop reopening (and rebleeding) with the slightest flexing, so actually filled the gap with stoopit-gloo to seal it shut. Eventually, the little wedge of glue just slid out on its own, quite effortlessly (and when I saw just how deep the blade went in), and I had a little “mouth” in that part of my hand for quite a while.
Can’t help thinking of this scene, and that if I had one of my knives and did that at the end, I’d probably bleed out right then and there.
isti242, i saw on your blog there is some PM3 on aliexpress now
if they make some micarta version i will order one
I picked up the new Sencut Snap with Cuibourtia wood scales. I’m impressed for the $45 this cost on Amazon. Between the gorgeous scales, skeletonized liners, sweet action, solid lock-up, and great blade steel; this is on par with much more expensive knives. The Sencut knives use the same 9Cr18Mov as the Civivi knives with WE’s heat treatment. Effectively, it’ll out-cut any other 9Cr18Mov and a lot of the Chinese D2 out there.
I wasn’t sure if the handle would be comfortable based on the pictures but it is. Just know that the stonewashed blade looks a little more gray IRL.
Only G10 versions are available at the moment. Thanks to the ball bearings the action is pretty good. Have a look at here. :sunglasses:
i just received a carbon bugout, so i can wait for more color or material choices
Did you go for the Jufule version with real D2 blade?
Wow, what a nice traditional’s knife!
Where did you buy it?
Thank you
it is from “JUFULE Knife Tools Store”
the seller description says it is real d2, since D2 steel is cheap and common in china maybe it is
but the carbon handle is realy nice with the blue anodise parts
had anyone tested material with tester file?
worth 35 bucks?
Sure!
NICE! I’d been holding out for a lightly used Spyderco kitchen knife, but frankly this one looks amazing. Where’d you find it for $35?
Just over a year of ownership. The Asher Nomad.
This is my EDC knife. It still looks just like it did the day I got it. Totally beautiful minimalist flawless performing knife. So glad I picked this up and Justin gave me excellent customer service (replaced my 1st one that had some blade play in it).
The short answer is yes, they perform ok. And when I say ok, I’m comparing that exact knife of which I have 3 to mach more expensive cooks knives from Henkle, Trident, Felix, F-Dick that cost a lot more and come out of Solingen Germany. They come very sharp but lack the weight of the German/Japanese cooking knives. But for $35bux well they are ok. I bought a flipper Twosun knife two off eBay that I’m very impressed with. Very well made, great precision. I wouldn’t pay hundreds of dollars for a twosun knife but the metals on their outdoor knives I believe have been tested so they apparently are what they vkaim them to be.
