Ok here are two shots, comparing two different emitters. One is a Nichia Optisolis at 5000k, with 99 CRI and 90+ R9, with slightly green tint (barely). The other is an array of Osram CSLPM1.TG at very low output (Osram emitters get even greener at lower outputs). The Osrams are 65 CRI, unknown R9, and very green at low outputs. First shot is without tint correction applied to the Osram emitters, while the 2nd shot has tint correction applied to the Osram emitters.
Both pictures taken with a Sony A6300 and Sigma 35mm F1.4 using daylight white balance (5200k, +11 green), f/8, 2 second exposure, ISO 100.
As can be seen here, it’s very hard to discern the two emitters once tint correction is applied to the Osram emitters, at least when it comes to illuminating wood (low saturated oranges and reds). The amount of CRI or R9 here makes very little difference compared to the tint of lights.
I’m not trying to advocate for Lee filters, nor am I trying to say CRI isn’t justified. I’m merely trying to prove my original point in regards to the topic creator, in saying that CRI is a much more subtle quality of light compared to CCT and tint deviations. I love CRI lights myself. My favorite lights use 95cri E21A 4500k emitters and 95cri 4000k SST20 emitters with quarter minus green applied over them. However, I want to reinforce the idea that CRI is but a small portion of what makes a light pleasing to the eye, and can only be truly quantified with all other things being equal: that is equal CCT and tint deviations of two lights. Otherwise, those differences will overshadow CRI. Posting pictures comparing two lights of vastly different CCTs and tints doesn’t do much when making an argument for CRI.
great photos!
thanks for taking the time to show those examples
I appreciate your contributions to a very detailed an nouanced discussion
I see your point that once you add a lee filter to alter the tint of a low cri light, it seems to make the wood you used, look almost identical to the high cri light. I found the same effect when I put a minus green on a Low CRI LED… the wood looked very similar.
I agree Tint is a dominant variable in photo comparisons.
High CRI is very difficult to demonstrate in photos,
it is a more subtle component of light quality, than Color temperature and Tint.
btw, what is +11green setting doing for your photo? I dont have experience with manual cameras… I only learned the little I know about photos, from using my iPhone… You obviously have control of a lot more parameters.
generally speaking, High CRI LEDs tend to have less green tint, and warmer color temperature than Low CRI LEDs.
It is also true that we can alter the tint of a Low CRI LED, by adding a pink gel, so the two images look similar, even though they are not even close in CRI. I agree the wood in your photo is a poor target to demonstrate CRI.
Photos are a very complex medium, and it is much easier to show Tint and Color temperature, than CRI in a photo… White Balance is also an important variable.
I understand your wanting to equalize the variables, so we are only comparing one at a time… but that is now how LEDs arrive
LEDs arrive with a package of features that include CCT, Tint, and CRI… they are bundled together… So, when I suggest a High R9 priority, it also includes Tint and Color temperature considerations, that I dont necessarily mention. They all matter, to me.
Another variable I dont usually bring up, but I will now, is how I “feel” when I use a certain CCT, Tint, and CRI… I find CW Low CRI, and also NW Low CRI make me feel “washed out”, or “color deprived”… its difficult to find words for feelings… but I like the feeling I get from High CRI, and especially from high R9 CRI… as opposed to LEDs with low R9…
but even after all that, if the tint is green, I wont be happy with a high R9 CRI LED… the SST is a perfect example of that… it has great 90+ CRI R9, but with green tint. It makes sense to me that you would want to put a minus green filter on an SST…
I think we have similar taste in tint, as I would want a minus green on an SST also
I reach a similar goal,
by installing an sw45k, which also has 90+ CRI R9, and does not need a minus green filter,
I understand we can reach a similar tint, using an SST with a minus green filter… Personally I avoid Lee Filters, the sw45k works for me
I respect others preferences will differ…
question, given the lumen penalty from using a Lee Filter on an SST (which has higher output than 219b), does the SST with minus green filter added, still have a Lumen advantage over an sw45k? And if so, can you inform what Percentage brighter the SST w -green is, to an unfiltered 219b?
for reference
a 50% difference in lumens is only a small visual difference… it is the mode spacing of an HDS… each of the 24 steps on the dial is 50% brighter than the one before. 50% sounds like a lot, but it is not, when it comes to lumens.
That’s my bad… I meant to say +11 magenta. White balancing is just setting a true neutral white point, where warm to cool color temperature is completely balanced, and green to magenta tint is completely balanced. Since sunlight is slightly green tinted, my camera’s sunlight white balance factors in a little bit of magenta when set to sunlight white balance, because it wants to make whatever the sun lights up void of any tint. Since the Optisolis is designed to mimic the sun, it too also has that tiny bit of green tint to it, so this is the best possible white balance for the Optisolis. Other cameras’ sunlight White Balance vary from 5000 to 5700 kelvin, but they’ll all have a slight magenta boost to compensate for the sun’s tint.
I agree with that.
Depends on the tint bin of SST20 being offered. Fireflies has been good as of late for providing pink-tinted SST20s. The problem with the SST20s however, is they turn greener at lower outputs, whereas the Nichia emitters mitigate that. Having 12 SST20s in my ROT66, each individual emitter is really low output for most of my usage, so the 804 brings them back down to a neutral duv (to my eyes anyways). In turbo modes, they look just as pink as SW45k.
great info! thank you
I agree that Sunlight has a higher DUV than Incandescent, and that the Optisolis also has green tint…
I think the Optisolis makes a great daytime light, as its green tint is hardly noticeable, when sunlight adapted…
I sold my 6500k Optisolis for two reasons
the color temperature was “too” blue for my after sunset use
and the green tint was not to my liking in the evening, when I was adapted to incandescent
otoh, 6500k is a good option for a mechanic working in the sun… the sw45k is pathetic for that…
I think Tint is affecting peoples judgement here .whenever you put two lights side by side you'll almost always choose one over the other and even your favorite high color rendering light suddenly looks green when side by side compared to a "Better" emitter. So everyone knows what subjectively they think is a better light . John is just comparing his own lights against his own lights and noting what he subjectivly thinks he likes best .
The somewhat green hi cri sst 20's and the high cri 219C's made everyone rethink what they thought was true of hi cri . The rosyiness of the 219B 45k made lots of people equate red or rosy as being high cri .
Being able to fix a tint with a Lee filter ..and doing it to a green tint that almost everyone considers as just plain nasty is a pretty easy and quick n dirty fix .
the issues of the uv coated lenses that Olight and 4 7's used for so many years that created foul green tints hasn't even begun to be addressed . Or the fact that the newer emitters in general seem slanted towards green too.
My simple thought is that high cri is paramount ....output is relative and pretty limited in most cases and tint can be fixed or modified . but low cri is only fixed by changing the emitter .
I used to love to bring up the inverse square law to illustrate the point that your brain can't see moderate increases in power .Visually the differences between 300lumens and 600 lumens is minuscule ,it looks like someone made a bad mode spacing choice on a driver .... but you can't miss the difference between low and high cri ..My point was.. I want to pay for what I can see ..Not what I can't .
XM-L2, 3000K (don’t remember, between Ra 80 and 85, Opple is undecided)
XP-L2, 5D
I think the camera does with AWB what our mind does, so this is a fair comparison. Data says, the color rendering quality should degrade top to bottom. Eyes say…?
bottom two inferior as expected, 2nd is compensating its crap r9 by being low cct. also, cri is only really perceivable on natural high contrast items, like skin. wood works, but it’s lower contrast than skin a lot of the time. plus, the cameras people use are not great - and most are in sRGB space, which is drastically smaller than what we percieve. not to mention many monitors are crap.
Either way, 4000-5000k is ideal, and cri doesn’t matter a whole lot except on high contrast natural items. the biggest issue with most LEDs is blue bump, cyan dip. the red dip is not very perceptual to our eyes, because we hardly see the cutoff anyway
In direct comparison with the bottles the SST-20 wins hands down. The XM-L2 is not bad, but a little weak on cyan. The Samsung is terrible. Outside, the 4000K SST-20 feels a little to warm, but still performs incredibly.
Rendering comparisons on a single piece of wood without other other colors around is a fairly useless comparison other than simply showing how that particular object looks under the light. Where CRI/Ra really shines is giving more comparative visual information. A rosy tint will make the wood look good, but it also makes everything ELSE look very rosy, which may be pleasant, but doesn’t offer the same benefit to distinguishing/identifying colors.
I’m not convinced that we can assign a very specific color temperature to the midday Sun without specifying where on the earth we are and what season it is. However assuming we can even get close to a specific number, whenever the sun is out I have sunglasses on. Even if the Sun is hidden behind a whole lot of clouds, I have sunglasses on. If it’s raining and I’m driving I have sunglasses on. I don’t like the color temperature of midday Sun. I like it a lot warmer. I have speculated in the past about people that live in city or suburban areas with a whole lot of extra street lights and signs and so forth somewhat being accustomed to cooler temperature lights.
because the blue can looks different in every shot, it tells me the WB is different in every shot. But that said, I like the SST “best”.
I also like the 2700k LH351d, but, I almost never use such a warm light, unless I am waking up in the dark… I would never use it during daylight adaptation, not even under incandescent…
There are two ways to fix white balance differences…
1. if taking separate photos, dont use AWB, set to a consistent 5000k WB, or daylight white if the camera does not specify…
2. If you dont have manual white balance, then all lights should shoot separate cans but all in the same photo, lined up side by side… just the can with the fruit colors… leave the blue can out of the photo completely (and dont overlap the spill of each light)
opinion:
The colorful can is not ideal because it is not natural, organic, red pigment… would be better to line up some tomatoes, or strawberries, not oranges, they are not red enough… but a lineup of red objects might not work… to show the difference in a photo, that may be more obvious to your eyes
bottom line is that it is very difficult to photograph to reveal CRI… I trust your eyes and personal impressions, more than photos. I also rely on maukkas spectrum charts, to show the actual R9 value, those tell me the SST has the best R9, much better than LH351
one of the easiest CRI tests I have, is the palm of my hand…
in any case, congrats your your selection of test LEDs… hope you find the ones that work best for you
I chose those LEDs more or less randomly. My choice depends on ambient light. The Samsung was never a favourite.
The use of AWB is a result of my beamshots on TLF. It makes a picture taken look like I perceived the original scene. E.g., in the darkest night even a 6000K XHP70 looks good imo. Adjust the cam to 5000K and the picture looks terrible.
The woodwork in my house appears more like it really is with a higher CRI light. Maybe I can tell more than others because I stained all the trim and doors myself and made and finished much of the furniture. The stained woods have a certain amount of reddish tone to them. When I walk outside around the home or through the woods the brown pine needles and pine cones on the ground are more distinguishable from the grey and black earth. The green grasses seem to be more true to color. The old (red) McCormick IH tractor is truly red as is my Tacoma. The funny thing is I used to accept what things looked like with low CRI lights. But now I see the difference and it can bother me to see falso color rendition when I can have a choice for higher CRI.
Since it seems the LH351D emitter in my Skilhunt isn’t the best high-CRI emitter, I’ve ordered a Skilhunt E2A with an SST-20 high-CRI emitter to do some comparison.
(Also heard that someone ordered a Zebralight with a supposedly high-CRI LH351D and it turns out it wasn’t really high-CRI at all, so I wonder if my emitter falls in that same mediocre batch.)
It’s important to note a 5000K white balance does not fix white balance differences. Setting a consistent color temperature fixes white balance differences. It could be 3500K, 3000K, or 2200K. The important thing here is to shoot at the same “K” or kelvin rating.
Your going to be comparing the first one at 5000k to the second one at 4000k. You’re almost guaranteed to like the 4000k hi cri. You won’t ever want to get anything above 4000K again.
