Prices are very high if you’re looking at them in usd, but it’s nzd although I still need to make a living somehow
New Zealand customers only as exporting is problematic. I give lifetime upgrades and free labour on repairs after 1 yr warranty to make the prices worth it
The focus is bad without height adjustment of the reflector and so I’ve told Simon the thickness gasket of what’s needed.
Ah, thanks for the explanation, forgot that its NZ$ which is obvious different than US$.
No need to excuse, i understand that its part of your business and you have to make a living.
Was just hoping that BLF enthusiasts can buy it from Simon, since most of us are familiar with Convoy and modding.
I definitely understand. we wouldn’t want the spill from the light to disable, distance vision. Poaching must be minimal out there. Most state’s here, if you have a rifle and a good light at night, Someone will investigate you.
It’s 26mm so it’ll fit even if it can’t clamp in all the way.
This needs some major adjustments though for the Osram LEDs, but okay for the Luminus SFT40.
The focus is way out and the reflector needs lifting up. I’ve been modding these for my store and they’ve been selling like crazy. I made $1500 in two days, that’s usually 1 month of sales right there.
You can’t use the 8A Convoy driver since it doesn’t have a positive spring so you’ll dent in the batteries from the recoil and possibly damage the driver over time. Okay as a handheld though.
Pressure switches are in production.
Check out my YouTube videos of the Osram culpm1, cslnm1, and green, red
If you have a bit of modding experience you can turn this into the best budget gun light available
I have been using a C8F with my AR for raccoons and short range coyotes. For my longer range stuff, bolt guns and magnified optics I use an XHP-50.2 that I built that is well focused and driven pretty hard off of 2 26350 cells. Something like this new L21 might be and interesting replacement for that kind of work. Last time I checked, we can’t use real night vision in IL also no suppressors, so the big 6mm-284 does not get used often at night and I can only light out to about 400 yards and still use my 8x32x optics. Plus the darn thing goes so fast that I am not sure what a suppressor would really do for it.
Just read this topic, in fact I’ve just received this new light the other day, and I would like to improve the beam on it, because now it’s got like two donuts , I would prefer only one ,more concentrated , do you think this idea would be feasible with the gasket included ? I mean raising the reflector ? Thanks
Which led version do you have? The factory messed up the focus which is why the focus hasn’t been very good. I got the correct size gasket made for the Osram chips, it’s only the SFT40 that needs adjusting, but I’m personally quite happy with it since the large corona helps out hunting to track an animal, if it runs after the first shot. It still could be worth correcting though
