Test/review of Evva 21700 5000mAh (Black-silver) 2021
5 posts / 0 new
HKJ
HKJ's picture
Last seen: 6 hours 33 min ago
DSC_4315
Official specifications:
  • Nominal Capacity: 5000mAh
  • Minimum Capacity: 4900mAh
  • Nominal Voltage: 3.6V
  • Standard Charge Voltage: 4.2±0.5VV
  • Standard Charge Current: 2A
  • Max. Charge Current: 4A
  • Protection Circuit: Built-in, with over charge, over discharge and short circuit protection
  • Std. Discharge Current: 5A
  • PCB Protection Trip Current: 15A
  • Discharge Cut-off Voltage: 2.50V
  • Dimension: (D)21.60mm*(H)75.60mm max.
  • Weight: 75g max.
  • Cell origin: A Grade Samsung 21700 cells
  • Operating Temperature: Charge: 0°C ~ 45°C, discharge: -20°C ~ 55°C
Evva%2021700%205000mAh%20(Black-silver)%202021-info
This is a high capacity 21700 cell with protection.
DSC_4314
DSC_4316 DSC_4317
DSC_4318
DSC_4319
Evva%2021700%205000mAh%20(Black-silver)%202021-Capacity
The two cells match very nicely and the protection kicks in at higher currents, but it is a bit slow to reconnect the output, i.e. it failed to reconnect during my automatic test and I did not get all the curves.
Evva%2021700%205000mAh%20(Black-silver)%202021-Temp-5.0
Evva%2021700%205000mAh%20(Black-silver)%202021-Temp-10.0
Evva%2021700%205000mAh%20(Black-silver)%202021-Temp-15.0
Evva%2021700%205000mAh%20(Black-silver)%202021-CapacityTimeHours
Evva%2021700%205000mAh%20(Black-silver)%202021-Energy
Evva%2021700%205000mAh%20(Black-silver)%202021-Charge
Discharge-Evva%2021700%205000mAh%20%28Black-silver%29%202021-pulse-1.0%2010%2010-IR
Conclusion
This is a good protected battery.
Notes and links
The batteries was supplied by Eeva for review.
Graphical comparison to 21700 and other batteries
Table with all tested LiIon batteries
HKJ
HKJ's picture
Sorry about the long pause from my last review, I lost the harddisk with all my data on it and it took some time to get my computer back to normal. There was no data loss, I have up to the minute (more or less) backup.
raccoon city
raccoon city's picture
Last seen: 12 hours 54 min ago
Just curious...
What program do you use for practically constant backups?
HKJ
HKJ's picture
raccoon city wrote:
Just curious…
The program that is included with my NAS server (Synology), but I would have preferred something where I could specify a minimum time, that would make it possible to maintain multiple generations of a file I work on.
One detail I really like about the backup program is that I can fetch latest generation file from the NAS server without any special software.
Superstocker
Superstocker's picture
Last seen: 10 hours 14 min ago
Thanks for the review. It is much appreciated. Sorry for the trouble with your hard disk too.
