AA/CR123 light
Streamlight 1L-1AA, Compact II, and Protac 90 all run on both without changing anything, just drop the cell in and run. These will also run on a AAA in a pinch.
If you have the right adapters, just about any C or D cell light will run on both and many more cells:
No li-ion. I have plenty of 18650 format lights.
> Any lights that accept AA/cr123
what prompted your interest in that combination?
These two lights can use AA or CR123 or also LiIon:
V11r with AA extension, as on the left:
V10r Ti with AA extension, as on left:
PM me if you would like to consider a purchase…
good luck with your search…
there is a UTorch that does that
it’s actually decent, the UTorch SF01
I have one, it was on some kind of sale about 3 years ago
under $10 or i would not have bothered
may be a clone
the body is long enough for an AA, and big enough for a CR123
the spring takes up the slack, though an AA does rattle from side to side a bit
not sure if an AAA goes in or not, i Have AAAs so i have not tried
it even has a 2 level UI that is kind of different and cool
programmable, i.e. the user can program 3 different modes: High/Strobe/Low (factory default); High only; and Low/High, to program you have to tap the switch rapidly 9 times and hold it down the 10th time, keep holding the switch until the light turns off, then release the switch. L
https://www.gearbest.com/led-flashlights/pp_009967770927.html
and the light color is a nice neutral with no blues or greens or purples
Have plenty of 18650 lights. Thought I look into a light that takes both batteries I can get locally during emergency.
I remember someone said during an emergency; most of AA, AAA,C,D are usually gone. Hopefully can find cr123 if I really need it.
that makes sense
good a reason as any, to buy another light … lol
I also like the excuse to get a solar panel, to recharge my eneloops and LiIons.
Slippery slope…
enjoy the ride
share what you buy
Although I have too many flashlights anyway, my go-to emergency flashlights are:
1. 18650 flashlights that accept CR123’s. I also have a box of CR123’s in the closet and get new ones every 7 years or so.
2. Just about any long runtime rated AA or AAA light. Currently, for me it’s a toss up between two Coast Polysteel lights… I keep the smaller one in the car glove compartment with a Big Larry clone if I need to change a tire, etc.
Something else to consider, is that some 21700 lights come with a 2xCR123 adapter… and some will accept an 18650 in the adapter (not all).
As someone already mentioned, Streamlight currenltly offers a AA/CR123 light. I have an AA/CR123 Fenix headlamp in my emergency bag, but they stopped making it… or at least they stopped making the extension for the AA.
Thanks, I’ll look into it.
I could buy a spacer to run my 18650 lights with 1 cr123…
I 3D printed some 18650 to CR123A/16340 adapters:
Thank you, xxo. I will keep you in mind if I decide to go that route.
Probably pretty easy to make a spacer using pvc pipe or a wooden dowel
Streamlight 88087
https://www.amazon.com/Streamlight-88087-Right-Angle-Lithium-Alkaline/dp/B07NSFVTMM/ref=sr_1_73?dchild=1&keywords=streamlight&qid=1623761442&sr=8-73
This Hugsby takes everything These are in every bag I have.
http://kaidomain.com/S024629-Hugsby-XP-18-Cree-XP-E2-R3-250-Lumens-3-Mode-LED-Flashlight-Black?search=hugsby
The Olight Transformer set.
The TC10 and TC15 are “vintage” Olight tube-lights. Normally in alu, sometimes SS.
Then came the SE Titanium Transformer Christmas set: 1 head, 1 tailcombo, 2 bodies.
An omnivore, you could feed it: AA, CR123A, 16340, and 14500.
dead link.
This looks promising. But missing a lower low mode. 40 lumen low seems a bit high.
No, it isn’t. You need to copy the whole link, included “search=hugsby” into the address line of your browser, and then delete the words (link is external). Well, that works for me!
Thanks.
I think the one I received has am XPG 2 in it . I’ll have to look.
