I have both the EA01S and the MF01S too. I suspect the greater mass will result in this hanling heat better, should equal the EA01S, be slightly less max output than the MF01S for a short time, because that MF01S gets insanely hot quickly. The MF01S is a heck of a flood light while it can deliver all 15k though. I actually added a grip via the side tripod mount to use it without discomfort. That light gets hot!!!
I’m reviewing this light and I will say it’s really nice even for on land use. As broght or brighter than my ft02s xhp50.2 5700k with a lot of thermal mass. It heats up only moderately after a minute on turbo, which beats all but my fan cooled lights. Under water it would run til the cells dumped without throttling.
8 think it’s a great buy for under $80. Get the bundle for the batteries also.
thanks for sharing your experience with this light, can’t wait to put my hands on it. Mine is 500m away from me at post office, but they doesn’t work on weekends :zipper_mouth_face:
Sure thing. Ah bummer! One day til Monday though. I think you’ll like it.
Code not working Amazon US
yesterday I received DL70. I’m really impressed with build quality and 4x XHP50.2 power. I really like the tint, something about 5700K.
Below you can find my video with beamshots.
Is this a better flashlight then the Sofirn SD01 ?
Depends on your definition of better. It’s a lot bigger, heavier, takes 2x26650, but is a lot brighter. I got almost 12,000 lumens at turn on. It holds high output about like a ft02s set to 60 C on air cooling.
will update a new code soon
I am interested when the code becomes available
here is the new code T8RFAHN6
thanks, here is the new code :T8RFAHN6
The DL70 code at amazon.de is not working, maybe discontinued?
here is the new code :XCLRCHHZ
Thanks , ordered one
Ordered. Amazon. US.
Thanks!
Just received the light. My first dive light and it is actually really nice as a regular light. Thank you Wurkkos for the awesome light!
Thanks for the code! Just ordered one. Can’t go wrong with a completely waterproof dual 26650 light. Will keep it handy by the front door.
