I have seen several Surefire lights that include a clip that makes it go bezel up when stored in pocket. What are the practical uses for such a configuration?
I know for some small lights you can clip to your hat and use as a pseudo headlamp but what of larger lights?
The lighting element and the switch are two separate pieces. So yes, you can mix and match to create a lighted forward clicky switch. As far as whether you can buy a pre-made lighted clicky switch, I don’t know. They’re not very common on factory lights.
At the time I ordered, CSLMN1.23 C8+ was out of stock, so I ordered a CSLNM1.TG C8+ 12 mode to swap the .23 into but I just learned the forward voltage is less for the red Osram. I’m new at doing swaps and figuring out drivers so what driver should I use in place of the 12 mode driver I ordered? I want to probably order stateside because I have a certain time frame in mind for a project (4th of July…). So which driver can I use turbo or 100% for a good bit without frying the red?
I’m not sure Simon uses different drivers for those LED’s, his drivers arent that sophisticated.
i think you should be fine, maybe a good google search will give both currents.
The Convoy 4x18a flashlight sbt90.2 can be purchased with or without its 18650 batteries,
I don’t know anything about the included batteries, and I am wondering if it would be worthwhile to purchase them separately for a performance standpoint?
It looks like Convoy is offering 4 of the Liitokala 3500mah cells for an extra $18. I’m not too familiar with that particular cell and I can’t find any reviews or tests on it. All I can say is it would fall in the “high capacity” style which looks like it would be fine for this light. Does anyone know the driver type of the SBT90.2 version? If its a FET driver you might be able to squeeze out some more lumens, but only when measured. Its doubtful you would see the difference with your eyes.
Those included cells should be fine.
I feel like i should be able to understand this by now, but every time i think i do i realize i dont.
Regarding XHP35, XHP50.2 (NOT 3 volt), and XHP70.2
-Are they all both 6volt and 12volt, depending on how the LED's mcpcb is made? Or are xhp35 and xhp70.2 12 volt, and xhp50 6 volt?
The reason i'm confused (i feel compelled to explain) - i have asked Simon @ Convoy numerous questions about putting a xhp35 in a xhp50 (6 volt) light he offers on his page, or about putting an xhp50 in a xhp70.2 light he offers on his page, or any one of the combinations you could think of between these three LED's and all the awesome offerings h has for them.
Sometimes he says yes it can be done, and sometimes he says no it cannot. Just today he told me the xhp35 could not be put into the M3c-u light he has because there is only a driver for xhp70.2 so far. What does that mean? if they are the same voltage, would there be another reason they wouldn't be compatible? Could the amperage be too high for the xhp35?
Also, based off of Simon and my conversations, i was sure i knew that the xhp70.2 was a 12v LED< but then looking on his AliX store today ( i do this often) i found the LED offering for a "xhp70.2 6volt on 25mm mcpcb".
So now i am lost.
NOTE: * I am NOT blaming Simon for my confusion. I feel like if i actually spoke face to face with someone who knows this information, i would've understood it months ago, but sometimes with the "back and forth" of the computer, key info gets lost to my brain. thats a "me problem".
What volts are these LED's? Or is the voltage for these particular LED's determined by the mcpcb layout? (i feel like once u/cncman shared pictures with me of 12volt mcpcb's vs 6v mcpcb's.
Page 28 of the XHP70.2’s datasheet ( https://cree-led.com/media/documents/ds-XHP702.pdf ) show this image of the bottom pad where you can see that the outside pads are split to allow for more than one configuration. This allows the XHP70.2 and the XHP50.2 to be configured as either 6v or 12v.
Wow, thank you for this in depth look Marc E! I really appreciate it, this helps a lot. I have looked to the data sheets to find this information before, but admittedly never went to the "back end" of them (P.28) and looked, thats why i probably never found the information i was looking for. although if i did see the items you shared, i probably wouldn't of understood what they are depicting anyway, without an explanation like you provided. So, thank you very much!
It seems you have this figured out now. I’ll add a little bit more.
In order for the xhp35 to be tightly packed, Cree actually joined the edges of the core in such a way that there are no wires connecting them. See below.
This gives them virtually no gaps between the cores and you get a better result (tighter beam, less artifacts). There are only 2 electrical contacts on the rear.
The xhp50 and 70, on the other hand, have the cores separated. The 50.2 and 70.2 have the same gaps, but the yellow phosphor is just spread all over minimizing the gap appearance.
It’s cores are wired such that 2 of the cores are in series and the other 2 cores are in series. You then have 4 connectors on the back. The MCPCB is what determines if it will be 6v or 12v. It can connect the 2 series cores in parallel for 6v or it can connect the 2 series cores in series and you get 12v.
The newer 3v version of the XHP50.2 has the cores internally wired all in parallel and only have 2 electrical connections on back. This is why it’s 3v only.
Keep in mind that these 4 core leds (xhp50 and 70) are basically just 4 smaller 3v leds combined. You can see the combinations in the second picture I posted.
